Cold Start Idle Noise
Old January 4th, 2008, 02:10 AM   #1
OcOnnor220 can only hope to improve
My 2001 GT has about 115,000 on it, all the stock parts are still doing fine but now out here on LI when its 9 degrees at 2am, I start it up and let it warm and there is a rather loud squeeking sound coming from an area that sounds like behind the left fender so I was thinking clutch..its a sporadic metallic rubbing sound that slowely fades as the car warms up. Its driving fine, aside from the gear box and clutch being stiff and sluggish in the cold before its been driven a few miles its ok. I had the same problem with my 96 GT when it would idle in the cold. The thing is the only part I could see making that sound from the clutch would be the either of the bearings...cause in neutral obviously the clutch is disengaged. I just had the oil changed and my block is fine theres no fluid leaks I have no exhaust leaks or loose or severed hoses that I know of I dont really think its an engine sound again it sounds a lot like its coming from where the clutch assembly would be. After the car is warmed up and been driven a few miles it idles quietly...again, it only does this in the very cold weather but tonight it was a little louder and more frequent than past cold days in the 3 years ive had this thing.
Threads Similar to: Cold Start Idle Noise
problem with cold start 6banger96 V6 Mustangs 5 November 7th, 2007 04:49 PM
START IDLE, RUNS THEN DIES slownomo All Other Vehicles 6 October 6th, 2007 12:20 PM
4.6 cold start engine knock jasons_98gt 96-98 8 July 7th, 2007 04:08 PM
should my car be stalling/surging on cold start with a cam? WhiTeFoX5point0 5.0 Mustangs 4 August 26th, 2006 01:42 PM
5.8/351 Windsor Cold Start Stall thunderbird885cc All Other Vehicles 2 July 3rd, 2006 01:27 AM
