2003 Ford Mach
Traveling at the speed of a photon
How would you comapre these to Bosch?
Sparkplugs.com - Application Search Results
i was comparing the bosch double platinum vs the NGK GP platinum (under super class)
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] |
Billy Weston
I personally would run an AR103(one step colder) or AR104(I have to double check that they would fit a 4v). Although they don't last as long as a platinum, copper is far superior when it comes to performance applications.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
2003 Ford Mach
when you say performance applications you mean those either with force induction or major bolt ons like high profile cams heads etc etc. i dont have and dont plan on going that route for a minute. i took the 2x platinum just based on longevity. i was more concerned about efficiency, durability and performance.<---i dont expect a fraction of hp with them but would like to know if theyre recommended on this motor, smooth idle etc etc
#4 | |
Billy Weston
Gun Whore
04 Whipple Cobra
10.61@129.96
IMO nothing compares to NGK. they are the stuff.
Modded Mustangs Make-A-Wish for Bubba "BWAL09" [url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url] [QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE] |
2006 Mustang GT
I would not run Bosch saprk plugs in my freakin lawn mower. JUNK!!
If you want a good plug stick with Motorcraft/Autolite, NGK makes great plugs and so does DENSO.
![]() 2006 Mustang GT-Borla Stingers, MGW Billet Interior & Underhood, Eibach Pro Kit w/Tokico D-Specs, Steeda Sway Bars, CHE Suspenson Upgrades, BBR Billet Control Arms, Foose 20" Nitrous, BFG g-Force KDWII |
Champion FTW, I run 'em in everything I own.
You don't need double-platinum plugs in a new-edge 'Stang, the COP ignition system has a conventional negative polarity (center to side electrode) spark--double platinum plugs are only needed for wasted spark systems where the "other" plug fires with "positive" polarity. FWIW--Many OEM plugs for wasted spark systems were built in negative and positive firing versions, with precious metal electrodes on either the center or side electrode depending on what hole they went in to--probably save $0.10 a plug on the assembly line...
-cliff knight- My Mustang 2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch 3.73s, 262 rwHP/305 ft.lb. Flex-fuel: burns gas and rubber... |
Threads Similar to: How would you comapre these to Bosch?
| Bosch "Iridium" 4-prong spark plugs - Anybody use | TCSoff | 2005 - 2010 | 5 | July 11th, 2007 10:19 PM |
| Bosch Platinum +4 Plugs | Patterson98GT | 96-98 | 16 | April 30th, 2007 12:07 PM |
| Bosch Platinum +4 plugs | Juggalo_X | V6 Mustangs | 20 | April 24th, 2007 02:32 PM |
| bosch o2 sensor heater issues | mustang_montana | 96-98 | 2 | June 25th, 2006 06:50 PM |
