Valve Train Noise?
i got 02 gt 2v geting nois from the top end as if the valvs or timing is off
runs fine at 1500 rpm or greater but at idol the motor is jumpin round like its got a problem and the car has 51000 miles on it is there a set time for valve ajustment? or somthing..... help please
do you havea timing adjuster on it. Steeda makes a good one, other than that I don't know, you iac valve could be getting clogged up.
your iac would have nothing todo with valve train noise. im not an expert at it but if it sounds like something is loose or knocking around in there, you might wanna pull the covers and see if there is anything that has come loose and may have a little play in it thats no supposed to be there
nois..
yeh it just sounds like its out of ajustment or something and is running like has bad gass during idol or maybe sounds like its detinating a little
i have no timming ajuster other than the hand held tuner but was not doing it befor only now ...yikes thanx for the input
Threads Similar to: Valve Train Noise?
| Cam and valve train??? | flamed 98 gt | 96-98 | 8 | November 2nd, 2007 02:58 PM |
| Crazy train ride | 87foxbodylx | The Clubhouse | 3 | June 26th, 2007 08:21 PM |
| Valve train clacking sound. Need help. | Maxwell881 | 5.0 Mustangs | 4 | March 15th, 2007 02:44 PM |
| valve train chatter question | USMC SCOUT SNIPER | 5.0 Mustangs | 0 | January 11th, 2007 10:19 PM |
| Drive train? | BravoTeamLeader | 5.0 Mustangs | 1 | December 17th, 2006 06:39 PM |
