Noob
Old January 7th, 2008, 12:10 AM   #1
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
Noob
what would need to be done to a stock block to make this work??
Pistons Included:Yes
Piston Material:Forged aluminum
Piston Style polished
Piston Rings Included:Yes
Piston Ring Facing Material:Moly
Piston and Ring Oversize (in):0.030 in.
Piston and Ring Oversize (mm):0.75mm
Rod Bearings Included:Yes
Rod Bearing Undersize (in):0.010 in.
Rod Bearing Undersize (mm):0.25mm
Main Bearings Included:Yes
Main Bearing Undersize (in):0.010 in.
Main Bearing Undersize (mm):0.25mm
Cam Bearings Included:No
Gaskets Included:Yes
Oil Pump Included:Yes
Oil Pump Volume:Standard-volume
Oil Pump Pressure:Standard pressure
Oil Pump Drive Shaft Included:No
Freeze Plugs Included:NoCamshaft Included:No
Lifters Included:No
Timing Chain and Gears Included:No
Assembly Lubricant Included:Yes
Plastigage Included:Yes
Notes:Approximate compression ratio 9.48:1 with a 51.8cc head.
sry noob ? but this is my first rebuild
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
Old January 7th, 2008, 03:19 PM   #2
twogts4us's Avatar
twogts4us is on a distinguished road
Not sure exactly what your question is, but in doing a rebuild I'd have the cylinder dimentions checked and, regardless, hone the cylinders to promote good ring seal. I'd have the head decked to ensure proper alignment and sealing with the heads. Who are you buying this stuff from? What do they recommend?
My new ride - 2004 Torch Red Mach 1 #198012. Magnaflow catted X and Magnapack catback, Eibach springs, MM STB, K-mem brace and CC Plates, Pro 5.0 shifter, FRPP alum ds, UPR upper and lowers, Torq Thrust rims, MRT CAI, Steeda UDPs, Predator.
Old January 7th, 2008, 05:05 PM   #3
mpboy's Avatar
2002 GT
99.99@999.9
would 30 over be a good idea, this is the only time i plan on rebuilding this motor, next time it will be new
Threads Similar to: Noob
Noob from NC botlfed1 New Members Introductions 21 June 29th, 2007 04:34 PM
Noob saying Hi! Tim2002GT New Members Introductions 15 June 23rd, 2007 09:55 PM
IM A NOOB FastBack71 5.0 Mustangs 8 January 15th, 2007 11:40 PM
another noob HM26 New Members Introductions 8 December 1st, 2006 08:10 PM
noob stangliter04 New Members Introductions 5 August 16th, 2005 04:37 PM
