will i lose HP without eliminators?
Old January 7th, 2008, 12:15 PM   #1
1996 mustang GT/Mach 1
315rwhp 320rwtq
tcasoccer13 is on a distinguished road
My buddy has an 04 Gt and i have an off road H-pipe because i put on on off road X pipe on mine, he is going to order the eliminators for it this week but wants to go ahead and put the H pipe on. i told him he wont get the full gain with out the eliminators because the check engine light will come on. i just wanted to know how much the check engine light will rob him and see if it is worth it to go ahead and put it on and put the eliminators on when they come in the mail.
Old January 7th, 2008, 12:17 PM   #2
DanTheMan's Avatar
1995 Civic EX
Soon to see a Garrett 60 trim
DanTheMan will become famous soon enough
I think it'd just make the engine run richer..
My honda
Old January 7th, 2008, 12:21 PM   #3
Proud American
MustangMatt96GT's Avatar
Originally Posted by DanTheMan View Post
I think it just make the engine run richer..
Meaning you will lose power. When ever running rich, you are lossing power, running lean, means you are making power.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old January 7th, 2008, 12:26 PM   #4
DanTheMan's Avatar
1995 Civic EX
i'd personally just wait to get the eliminators.. like matt said rich=power loss
My honda
Old January 7th, 2008, 12:27 PM   #5
Trick Tuners's Avatar
KB'd GT
It wont do anything. The rear O2s are only used to monitor the Cat efficiency and are not considered in the fuel calculations. The rear O2s are commonly turned off in most SCT tunes.
Old January 7th, 2008, 05:57 PM   #6
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
+1, all it will do is throw a code once the PCM figures out the rear O2 sensors are saying the cats aren't working (this can take 30 to 200 miles)--the rear sensors have NO effect upon the operation of the engine...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old January 7th, 2008, 05:57 PM   #7
DanTheMan's Avatar
1995 Civic EX
well i've learned something today
My honda
Old January 7th, 2008, 06:03 PM   #8
2000 mustang gt
marcd is on a distinguished road
so if you have long tubes should i run mil eliminators on both sets of o2s?
Old January 7th, 2008, 06:09 PM   #9
cliffyk's Avatar
No, the front O2 sensors are essential to the engine's operation, it will run pig rich and throw a bunch of codes if they are missing, disconnected, or have the signal altered by MIL eliminators (this is what MIL eliminators do...).
from the '03 shop manual:
The front sensors (HO2S11/HO2S21) before the catalyst will be used for primary fuel control while the ones after the catalyst (HO2S12/HO2S22) will be utilized to monitor catalyst efficiency.
-cliff knight-
My Mustang
Old January 7th, 2008, 06:42 PM   #10
KB'd GT
Right, the upstream O2s are used for all part throttle fuel calculations. Sometimes there are a few tuning tricks to get them to work better with the LTs.
Old January 7th, 2008, 07:20 PM   #11
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
eliminators
not running eliminators will effect performance, if your rear 02 sensor reads no change from the front one it will tell your car that your cat isnt working, your car can go into a limp mode, it will effect your performance, ive went thru this before, any 96 and up stang will need this if you run no cats or even some very high flow ones, tell your friend to get those eliminators if he's gonna be driving the car
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Old January 7th, 2008, 08:04 PM   #12
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
I sure there is some kind of "safe mode" the car goes into when the check engine light comes on. It cant be helping performance, I'll say that much.
Bolt on list in Garage..
Old January 7th, 2008, 08:07 PM   #13
KB'd GT
I dont believe this. What were the symptoms you had that you determined to be limp mode?
Old January 7th, 2008, 08:11 PM   #14
johnr2001's Avatar
2001 GT
johnr2001 is on a distinguished road
sometimes it throws the cars computer into a safe mode sensing something is wrong and you will lose hp until its corrected with the eliminators or another way.
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,
443 RWHP/ 386 TQ
Old January 8th, 2008, 09:55 AM   #15
2000 mustang gt
so i only need to run them on the rear?
Old January 8th, 2008, 09:58 AM   #16
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
yep. only on the rears
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Old January 8th, 2008, 10:29 AM   #17
2000 mustang gt
how much of a gain will there be i did my lt and mid pipe a few months ago but just orderd the mil eliminators a few days ago.
Old January 8th, 2008, 10:47 AM   #18
Geoff's Avatar
1999 Mustang GT
13.99@99.99
Geoff is on a distinguished road
I don't know a whole lot about this but I know that right now on my car one of the rear o2 sensor's isn't working, there for throwing a check engine code...... the car is working fine!
BBK Shorty Headers
Flowmaster cat back
Ford Racing aluminum drive shaft
Old January 8th, 2008, 05:48 PM   #19
cliffyk's Avatar
The engine's operation on a EEC-V PCM is not impacted by failed rear O2 sensors.
It will throw a code, and you will fail inspection i8f you are unfortunate enough to live in a place that wants a squeaky clean OBD-II readout--however it does not and cannot affect engine performance, the rear O2 sensors exist solely for monitoring the performance of the cats...
-cliff knight-
My Mustang
Old January 8th, 2008, 06:10 PM   #20
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
I don't have mil's or turned off rears yet. I am sure it is not in limp mode because It runs just fine under WOT but is has been rich as hell and it seems like it is always searching for the AFR, this may have nothing to do with them but just thought I would throw that out there.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Threads Similar to: will i lose HP without eliminators?
Will I Lose Power? gkizzle3622 General Tech 5 November 15th, 2007 07:00 PM
help ..lose in power and shiffting becoming horrible unblock Modular Mustangs 17 September 8th, 2007 11:44 PM
One mans lose is my gain... or is it? Mrdestboi 2005 - 2010 5 April 7th, 2007 02:53 PM
Torque Lose? o3gtdgs 99-04 6 October 25th, 2006 01:47 PM
