2001 Mustang GT
14.51
water pump install
hey im wondering if replacing my waterpump/thermostat is easy... from what i know its just removing belt, unbolting pully, draining fluid(mine is new i want to save), take off water pump, replace thermostat, put new gasket and water pump on, rebolt pully. is this correct? also where and how do i drain fluid from?
FYI i did do a search for this and didnt come up with anything |
2002 GT
99.99@999.9
yea and theres a bolt on th bottom of the water pump housing you cant see, and make sure you clean the water pump gasket area up, it can be a little nasty, the thermostat is straight forward, and if you want to test your thermostat, put it in some boiling water, but there not expensive, and also make sure the bolts you take out go back in the right hole, they can be diffrent lengths
Threads Similar to: water pump install
| Water Pump | Badasstang281 | 99-04 | 2 | December 27th, 2007 05:40 PM |
| what water pump | 95wip | 5.0 Mustangs | 2 | June 25th, 2007 12:04 AM |
| Water pump ??? | Fastback GT | Classic Mustangs | 15 | February 24th, 2007 02:37 PM |
| Water Pump | cobralini | V6 Mustangs | 1 | August 3rd, 2006 06:48 PM |
| water pump going? | magnifistang | 5.0 Mustangs | 8 | January 12th, 2006 09:49 PM |
