Header install
Old January 7th, 2008, 06:30 PM   #1
HMStang217 is on a distinguished road
Header install
Im getting a set of ford racing shorty headers this week..i know everyone hates the shortys but i got a good deal on them..so my question is...when i install them.... what are the tips i need to do it correctly....has there been a write up on the correct install on here that i have not seen?...i know its gonna be a pain but i wanna try it..so help me out guys thanks alot
1996 Mustang Gt (ongoing project)
-Spec Stage 1 Clutch
-Mac Prochamber Midpipe
Old January 7th, 2008, 06:36 PM   #2
Gun Whore
04 Whipple Cobra
10.61@129.96
KingChronic will become famous soon enoughKingChronic will become famous soon enough
shorty headers arent even worth the pain it is to install them if you ask me.
if you got a good deal on them, sell them make some $$, and get some longtubes.
Modded Mustangs Make-A-Wish for Bubba "BWAL09"
[url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url]
[QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE]
Old January 7th, 2008, 07:08 PM   #3
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
on the passanger side, if you take the wheel off it helps you get to the back bottom stud, but wd40 the shit out of them the night before, and get you som swivle head attatchments and some extensions, it also helps if you jack the motor up a little, religion helps to, and some padded gloves FTW
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
Old January 7th, 2008, 07:11 PM   #4
Token asian guy
swervo's Avatar
'11 Grabber Blue GT
swervo will become famous soon enoughswervo will become famous soon enough
Send a message via Yahoo to swervo
I have to agree.
'11 Grabber Blue GT
swervo if I ever go gay I'm totally going to marry you
Old January 7th, 2008, 07:25 PM   #5
Thanks mpboy
Old January 7th, 2008, 07:26 PM   #6
mpboy's Avatar
2002 GT
99.99@999.9
i can give you a write up on how i did mine... if u give me a bit
Old January 7th, 2008, 07:26 PM   #7
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
headers
best hint or tip is just if you get mad and get really pissed off, go do something for half a hour or an hour and come back, besides that use the wheel idea, and def def def use wd40 or PB blaster to make sure the bolts are rusted because they can snap otherwise
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Old January 7th, 2008, 07:59 PM   #8
mpboy's Avatar
2002 GT
99.99@999.9
ok here we go (this is for a 2002 GT)
(this is for the driver side)
wd 40 the shit out of them (leave over night) if not you break the stud and ur screwed.
i use a couple of 3/8 extinsion, a 3/8 swivle and a 13mm socket with the groves that grab
the nut, go in and lock your stering wheel. then disconnect the sterring shaft from the
steering gear, dont let the steering wheel move, remove the EGR pipe from the manifold and
remove the 8 nuts, it helps if you remove the big nut that holds the motor to the motor
mounts, put a block of wood on the oil pan and jack the motor up till you get enough room.
the brake master cylinder almost broke my hand so watch out its the devil. taking the wheel
off helps there are all kinds of holes and stuff that you can acces the nuts from. when you
get the manifold off it drops down, its easier that pulling up through the engine bay, the
pass side is about the same, once you get the driver side off youll know how to do it.
clean the studs coming from the motor, clean the gasket sealing area, use new hardware,
and gaskets and then put you new headers on, i lubed up the studs with a samll amount of
wd40 when i put them on. after you get them on put every thing back together and start
your car make sure no leaks, and you should be good, and remember the motor mounts. i
forgot those when i done it
so 3/8 extinons (long ones)
13mm stripped nut sockets
3/8 drive
3/8 swivle
wd40
a friend
the motor mounts i broke loose with a 19mm socket and a breaker bar
a bible
Old January 7th, 2008, 08:02 PM   #9
RC02GT's Avatar
2006 Saleen s/c
RC02GT is on a distinguished road
Send a message via AIM to RC02GT
I just did mine and your gonna hate it, I put the shorty's on and x pipe at the same time and i can feel a difference but the install sucks sooo much, I would definately recomend dropping the k-member, I didnt and it sucked! It will save you time in the long run, trust me i spent 3 days on my back it was not fun, and you have to lift the engine up to to fit the headers in, you have to move the steering shaft on the driver side which is easy to do, you will have to have a swivel head for your ratchet, plenty of sockets, wrenches, extensions. Is it a DD?
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune
Old January 7th, 2008, 08:04 PM   #10
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
Herd of midgets
Old January 7th, 2008, 08:04 PM   #11
Gun Whore
04 Whipple Cobra
10.61@129.96
as RC said, so much easier to jsut drop the K member.
and liek i said, if your going to go through the bitch of doing headers, you REALLY should do longtubes. you probably talking about 3X the power gains if not more.
Old January 7th, 2008, 08:19 PM   #12
RC02GT's Avatar
2006 Saleen s/c
Yes all that work it will take your going to want to be satisfied, but if you need to pass emissions like I do I think LT's will give you trouble and you dont want to go through that install, I will guarantee you cant wait till its over. Buy percys seal4good dead soft aluminum gaskets, and ford racing stage 8 locking bolts, they will both run about $80 or so but WELL WORTH IT, you dont want to keep tightening bolts and have a gasket blowout, im so glad I bought them.
Old January 8th, 2008, 07:32 PM   #13
no its not a dd so i have all winter long to get it done its just sitting in the garage right now i have a lift to i dont know if that will help me at all or no
Old January 8th, 2008, 07:33 PM   #14
mpboy's Avatar
2002 GT
99.99@999.9
if you have a lift it will make it SOOOOOOOOOOOOOOOOO much easier
Threads Similar to: Header install
Header Install Help RC02GT 99-04 8 December 3rd, 2007 11:11 PM
Header Install zerofx150 99-04 24 October 9th, 2007 10:45 AM
header install superman5.0 5.0 Mustangs 15 June 30th, 2007 11:08 PM
header install dumps 2005 - 2010 8 May 18th, 2007 01:25 AM
Header install help lecherp 99-04 1 April 4th, 2007 03:18 AM
