Regular or Premium gas?
Old January 7th, 2008, 07:08 PM   #1
PowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nice
iTrader: 13 reviews
Does anyone know what the 2002 GT manual says what recommend gas to use? 87 or 93
Ive been putting in 87. I thought only the cobras are suppose to use 93. and what do you guys use and what is the advantages of using 93?
Old January 7th, 2008, 07:11 PM   #2
RAGEman's Avatar
1965 Mustang Fastback
N/A
RAGEman will become famous soon enough
I can't remember exactly what it says, but I know it says 87 is recommended. 89 or 93 is optional.
Old January 7th, 2008, 07:17 PM   #3
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
87 octane. No advantages with 93, unless u have a tune for it
Old January 7th, 2008, 07:21 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ exactly.
use regular
Old January 7th, 2008, 07:29 PM   #5
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
gas
of course theres a benefit to running higher octane, tune or no tune is easer to combust, longer plug life, its overall better for your internals as well, can lead to a cleaner engine to
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Old January 7th, 2008, 07:34 PM   #6
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Simply put, the octane rating of a fuel determines the propensity to explode
rather than simply burn when mixed with air and ignited.
Exploding is bad.
Burning is good. The higher the octane, the more resistant to exploding.
If you are running too low of an octane for your motor, you will get
pinging. Pinging in its extreme form is also known as detonation. The
fuel/air mixture is igniting all at once and exploding instead of igniting
as a flame wave. The resultant "bang" is very hard on the pistons, head,
rods, and cranks. I've seen bent rods, cracked heads, pounded-out crank
bearings, cracked piston skirts, and chainsawed crankcases (*really* bad
thrown rods!).
In an overly-simplistic nutshell (sorry JC!), chipping a motor will usually
advance the ignition timing, adjust the fuel/air ratio
, and modify several
other highly proprietary and secret things to increase performance. Among
the main factors in detonation are (1) heat; (2) compression ratio; (3)
octane rating; (4) fuel/air ratio; (5) ignition timing. Modifying any of
these factors can either increase or decrease the propensity to detonate.
Advance the ignition timing and you increase the potential to detonate.
Retard the timing and you decrease the potential to detonate. You can
balance these factors by modifying some to offset others. If you increase
the fuel/air ratio and advance the timing, you can raise the octane and end
up with more-or-less the same propensity to detonate as the non-modified
motor. Alternately, you could lower the compression ratio, but this would
cause a loss of horsepower and efficiency and undo all the gains of
modifying the mix and the timing.
run what it says to from the factory unless you have a tune for it.
Old January 7th, 2008, 09:07 PM   #7
iTrader: 13 reviews
OK thanks guys.
Old January 7th, 2008, 09:08 PM   #8
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
yup
Old January 7th, 2008, 09:45 PM   #9
johnr2001's Avatar
2001 GT
johnr2001 is on a distinguished road
unless you advance your timing premium really has no benefits.
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,
443 RWHP/ 386 TQ
Old January 7th, 2008, 09:50 PM   #10
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
AndrewA. will become famous soon enough
I alwasy ran reg. but every now and than i use to treat her to some good ol expensive gas.
Than the tune came and now all she wants is that expensive stuff
Old January 7th, 2008, 10:35 PM   #11
Paulnhbtx's Avatar
Paulnhbtx is on a distinguished road
I have the same car as you color, rims and... Dammit I have been using 93 this whole time.... was it a waste of money? I had a 87 GT and put reg gas and it knocked
Old January 7th, 2008, 10:41 PM   #12
99 cobra
N/A
gas
i never reccomend regular octane in any kind of performance car, its a high winding 4.6 modular motor ive always put 93 in everything i own, then again i do take 4 hours at least once a week to wash wax and and detail my mach, and i did the same for my v6 before i garaged it, as well as my 81 Z28
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
SCT MAF
Tune
03 cobra pumps
HVGC
Old January 7th, 2008, 10:44 PM   #13
00gtCoolGuy's Avatar
13.67 @ 99.3..5000 ft D.A.
00gtCoolGuy is on a distinguished road
are GT's performance cars? lol
2000 Mustang GT- 4.10's, Hoosier DR's, JLT, 75 mm TB, Plenum, MAC LT's, VRS O/R X-pipe, MAC Catback
13.671 @ 99.11 (1.80 60')
5000+ ft above sea level - in El Paso, TX
http://www.youtube.com/watch?v=U2l4JdEg3hg
Old January 8th, 2008, 12:42 AM   #14
sk8flip67 is on a distinguished road
With anything higher than 87 octane you have to watch out for additives. I think but not 100% sure that shell (i know there are/were several gas stations) adds or at least use to add some compound to their higher octane gasses. Cant remember their logic but long story short engines got messed up. The additives were eating away at the metal in the engine and other stuff. That may not be waht happened but i know for a fact that the additives casued engine problems and reduced life. Heard it from a mechanic about a year ago debating about whether 93 was worth the extra 30 cents at the time and also read it on a news website back then. Its not much help without the specific details, but id research what additives the gas station you use puts in their higher octane gas and search online and see if those were the additives that were destroying engines.
Old January 8th, 2008, 07:43 AM   #15
brianm's Avatar
2011 ram 1500 hemi
brianm will become famous soon enoughbrianm will become famous soon enough
i think shell had a prob with messing up fuel pumps on some cars, i forget which cars it affected. btw shell 91 is all i run
vmp500 hp. jba lts. powerhouse d/s Sold
Old January 8th, 2008, 09:10 AM   #16
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
yeah dude. hah. they arent that bad
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Threads Similar to: Regular or Premium gas?
SCT XCal2 - Premium or Regular Gas? AFtriathlete Modular Mustangs 3 October 12th, 2007 05:08 AM
silverstars or regular? energiesource 99-04 8 September 26th, 2007 04:20 PM
Regular check ups zrez 5.0 Mustangs 4 May 13th, 2007 08:52 PM
Regular check ups zrez 5.0 Mustangs 0 May 13th, 2007 07:22 PM
Premium or regular gas Mkenne4@tampabay.rr.com V6 Mustangs 10 October 17th, 2006 11:55 PM
