Svt Bov?
Old January 10th, 2008, 04:23 AM   #1
AnglicoGT98 is on a distinguished road
Send a message via AIM to AnglicoGT98
Svt Bov?
Just a quick question for anyone with a Termi or that knows anything about pass through MAF's....
Can you put a BOV on the '03 Cobra?? I'm sure there's a way....but I'm stumped...any help???
Old January 10th, 2008, 04:59 AM   #2
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
The By-Pass Valve does just that, it allows air that is being forced down the throat of your motor to be by-passed back into the supercharger or into the atmosphere, depending on the application, and the requirements of the supercharger.
Why, you might ask, is there a need to add more air by bolting on a supercharger and then take it away. The answer to that common question is, when you are force feeding a motor with air, there are times through-out the rpm-range where the motor can not handle more air. One example of this is, if an intake valve is closing on the cylinder heads, there is going to be a moment where it can not flow any air, but will imediately need air there after. Superchargers regulate the rate they flow air by the RPMs of the motor and not in those milliseconds through-out the RPM range that the motor can not handle the amount of air that the supercharger is forcing.
SuperchargersOnline.com :: Answering your questions about By-Pass Valves.
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
Old January 10th, 2008, 08:52 AM   #3
energiesource's Avatar
energiesource is on a distinguished road
just buy a friggen turbo if you want a bov.
Old January 10th, 2008, 11:57 AM   #4
Gun Whore
04 Whipple Cobra
10.61@129.96
KingChronic will become famous soon enoughKingChronic will become famous soon enough
what he said. but you dont hear the bypass valve at all.
Modded Mustangs Make-A-Wish for Bubba "BWAL09"
[url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url]
[QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE]
Old January 10th, 2008, 12:45 PM   #5
I understand exactly what a by-pass is and the whole atmospheric(BOV) vent or recirculating.... What I was trying to get at was, with a roots style S/C you can have it vent into the atmosphere right?? I'm not trying to find a way to get a "cool" sound...I just don't like the extra tubing to recirculate the boost. Any thoughts?? Thanks for the info thus far.
EnergieSource - Every kind of FI should have some sort or BPV/BOV, not just turbos. It gives better longevity.
Old January 10th, 2008, 12:51 PM   #6
Gun Whore
04 Whipple Cobra
10.61@129.96
no, its a pull through MAF cant vent to atmosphere or would cause tune issues.
whats wrong with the couple extra lines for the recirculation? the motor has tons of other vacuum lines, and your worried about a couple foot at the most of recirculation lines?
me no understand.
Old January 10th, 2008, 12:59 PM   #7
I always just understood that with a draw though MAF all you need is a intercooler, then you can put the BOV before the MAF. I know you can't put one after the MAF b/c you'd be losing acounted air.
Point taken, I guess a couple extra lines really wouldn't matter...lol
Old January 10th, 2008, 01:07 PM   #8
yes but superchargers at 9 psi...run at 9 psi. the onyl thing stopping turbos from running any higher than the set psi is the wastegate and the BOV so its more essential on a turbo
Old January 10th, 2008, 01:24 PM   #9
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
I forget which magazine, but I've read that a guy with a centrifical supercharger put one on his car. He could electronically dial in whatever pressure he wanted. I don't remember exactly but I think he was running around 23 psi on the track (racing gas) and 14 on the street (93 octane).
It would seem to me that at 14 psi his boost curve would be very similar to a turbo. Getting the boost early and flattening out.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
