LinkBack (1) | Thread Tools |
#1
Look Ma! My First Post!
Best Supercharger?
Which supercharger would be best recommended for my GT? The Kenne Bell or the Vortech? Leaning towards the Kenne Bell but I want to keep my options open. Any suggestions. My setup is pretty much stock. Just some JBA shorties and a JBA h-pipe to match.
Gun Whore
04 Whipple Cobra
10.61@129.96
for gods sake search back a few pages, this topic only gets covered about 10 times a week.
but the vortech will make more power, be more efficient, and easier on the motor. also better for a DD.
Modded Mustangs Make-A-Wish for Bubba "BWAL09" [url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url] [QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE] |
N/A 4v Guru
2003 Mach 1
If thats the only 2 choices then definatly the KB. If you would expand your options a little I would say procharger FTW!!
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
Gun Whore
04 Whipple Cobra
10.61@129.96
definently +1 on the procharger, the new paxtons are also damn good blowers.
procharger, vortech,paxton, kb, wipple<all will get you lots of hp
2004 Crimson red GT saleen s/c, full bolt ons |
N/A 4v Guru
2003 Mach 1
Although paxton has re-released their self contained units again, but they still may not be as good as a procharger. How you oil it don't make or break how good it is.
I dont understand. Why is the Vortech more efficient? When you say effiency.. your speaking in terms of? Im curious.
Gun Whore
04 Whipple Cobra
10.61@129.96
the centri's blowers make less heat than a positive displacement lower, which means they are more efficient.
1997 Mustang GT
Faster than an s4
Its not more efficient, its just differant. The way a twin screw roots type blower like a Kenne Bell makes power is differant from a vortech or paxton. The Vortech and paxton have a linear boost and power curve. They make more power the higher your RPM. But at low RPM, they make very little torque due to their design. The roots type (KB) builds boost much lower in the RPM than the Vortech, it will make slightly less power at peak than the Centrifugal Supercharger (Paxton\Vortech) but it makes a lot more torque through out the spectrum.
Check out this article for some ideas. Ford Modular Motor Forced Induction Dyno Comparison - Muscle Mustangs & Fast Fords Magazine |
Okay, so in terms of heat or tempurature, your saying the Vortech is more efficient? That seems odd to me. Anytime you compress air, you build heat.. if both superchargers move similar amounts of air, and have the ability to compress the air to within a certain level, the heat production will be around the same. The benefit of some superchargers, is an intercooler (you know that already) The KBs are intercooled. Your telling me that a non-intercooled Vortech(if thats the system he decided to you use) is more efficient with heat production, than an intercooled KB?
1997 Mustang GT
Faster than an s4
Because of the location of the Vortech compared to the KB, the heat will be greater at the location of the KB than the Vortech. But what you are not taking in to account is that the air from the KB goes straight in to the engine, rather than having to pass through your intake manifold and the piping to the TB. The only really important differance between the two is their power curves, and what type suites you.
Location means nothing when your using an intercooler. Why is the temp going to be higher with the KB? Because the air is being squeezed just before the intake port? It passes through an intercooler before it ever makes it to the port. Those air-to-water ICs do a rather nice job of bring down intake temps. Even besides that, the Vortech will squeeze the air just the same, and produce the same heat at the compressor. Without an intercooler, the intake temp will be very similar.
1997 Mustang GT
Faster than an s4
On a side note, Vortech's can be intercooled also.
#15 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
also, the vortech;s can be run with the paxton air to air IC system which is even more efficient, and less restrictive than the vortech aftercooler system.
N/A 4v Guru
2003 Mach 1
The major heat differnces are the fact that the top mounts use a heat exchanger and that heat soaks a little and they get engine heat soak. The centri's also use an impeller to compress the air and this is more efficent than the screws or roots. But your best bet is still a procharger IMO.
#17 | |
12.73@111.36
Considerations: Is your car a daily driver? Will anyone else other than you drive the car? Will you be driving the car in the rain or snow? A twin-screw reaches maximum boost at somewhere around 2,200 rpm. It has a lot of low end torque and some have said it hard to handle in bad weather. The centrifical supercharger builds boost gradually. Mine is 1.8 lbs at 2500 rpm and 8.9 lbls at 6,000. My wife seldoms gets above 2500 rpm and I keep it below that in bad weather so the car behaves pretty much stock. When I want the power its there.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#18 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i agree to expand options. you want a blower that takes no power to make power!!! i vote for the e-chargers!!!
i vote kb, between the 2. but i also recommend looking into procharger.
MasterDeBater
Procharger is still the leader in FI
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/50187-best-supercharger.html
| super charger help - Page 2 - MustangForums.com | This thread | Refback | May 10th, 2011 12:59 PM | |
Threads Similar to: Best Supercharger?
| looking to buy a supercharger?? | gtdan | 96-98 | 1 | September 7th, 2007 09:18 PM |
| 4.6 4v Supercharger | EvoEater8 | 99-04 | 7 | June 24th, 2007 11:45 PM |
| cam and supercharger | mmvi | V6 Mustangs | 11 | May 17th, 2007 12:36 AM |
| Supercharger | jes93 | 5.0 Mustangs | 6 | November 21st, 2006 08:53 PM |
| Almost About To Get A Supercharger | FireryDriver | 2005 - 2010 | 8 | October 7th, 2006 03:14 AM |
