how much horsepower from a termi??
ok im getting a termi in about a month or two and i want to make 550 horses..i will have 2500 to spend now what will i need to buy besides th tune to get it to those numbers??or should i just buy an kenne bell to just bolt up??what else would i need with the kenne bell since its also a roots blower??
Full exhaust-$1200
JLT cai- $230 Accufab TB- $570 Pulley-$80 Plus your tune I think youll be at 550, for under $2500.
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
Depending on if you do the install's or not.
Gun Whore
04 Whipple Cobra
10.61@129.96
it is quite possible the new stiegemeier stage 5 port will do that. the stage 4's were making up to 530RWHP, and the 5 is suppost to make even more.
$2500 wouldnt do it though, but it would be a start. you would need: Catback midpipe headers intake heat exchanger upper pulley lower pulley idlers KB BAP 60LBS injectors stage 5 ported eaton SCT Xcal 2 or 3 tune that is going to make the power, but is goign to be way more than $2500. also once you do that your going to need a clutch pretty soon the stocker is only going to take that for so long. to get to the 550RWHP mark i would do the following mods in the following order. i would take the $2500 and buy the first group of mods $350 used catback $500 used longtube headers, and X pipe $150 JLT RAI $265 new billetflow 4 peice idler set $150 new billetflow upper pulley 9i would buy a 2.93, anything smaller you will have to worry about belt slip $50 belt $350 new 4LBS lower pulley kit this and the 2.93 will put you at about 16PSI whhcih is at the top of the eatons efficiendy $290 LFP heat exchanger $200 used SCT BA2400 MAF (chances are the stock MAF will peg) $400 SCT Xcal 3 new with a mail order tune that is a about $2700. that will give you about 460-490RWHP, and anywhere from 500-550RWTQ. from there i would save for the next group of mods which would be $400-700 throttle body and plenum either accufab, or billetflow. you can find new or used, billetflow is the best $375 60 LBS injectors and harnesses $300 KB BAP with harnes upgrade $700 stage 5 port $300 custom dyno tune that is another $2000-2300 that will put you damn close to your 550RWHP mark. regardless whether you go ported eaton, or twinscrew though, you still need all those supporting mods injectors, BAP, MAF, HE, idlers, tune, ect. and the twinscrew will also run you $2000-3500 for a used blower depending what you go with, instead of the $700 for the ported blower.
Modded Mustangs Make-A-Wish for Bubba "BWAL09" [url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url] [QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE] |
Gun Whore
04 Whipple Cobra
10.61@129.96
the most he would see with that is 575RWHP MAX, and he would still need a heat exchanger, and a MAF.
13.00 @ 105
![]() iTrader: 1 reviews
split that money up and do a pulley swap, heat exhanger, exhaust, a bolt on or two & a tune. Should put you close to 480ish at the wheels... which i realize i alot less than you wanted BUT then put the rest to a solid axle swap b/c that IRS wont last long with the way you wanna drive it
![]() for the swap you are looking at: -full rear end (maybe 31 spline carrier and axles) -might as well stick gears in it unless you find a rear with some already in it -new catback -new springs & shocks -uppers & lowers (I still have my stockers laying around, plus my shocks) -whatever else I forgot ![]() Or you could just find a cobra with the swap already done and save the time & trouble ![]() if you know how to set gears, you can do the swap by yourself... its fairly easy. 4 bolts and the whole IRS drops out. Your ABS light will stay on though b/c you won't have the ABS rings for the sensors to read
well im finding one with alot of mods done already..i found one for 19,000 with whole solid rear swap and mods..then i found one that has 495hp and 554tq and he wants 20,500 but obo..so i might just find one with a full exhaust hopefully and maybe ported heads..im not going to buy no stock cobra though for sure cuz they are going around 25,000 for some reason..and as for the rear end..i have it on my gt remember..it has 3.73s in it already..i will get upper and lower control arms to..
yeah remember shocker..i have a shop or our business lol..i do and did all my own work so no labor crap for me..and i will pull the 6 speed our and upgrade everything to billet and higher heated synchros...i may throw my 100 shot nitrous kit on it also and get a custom tune when i hit it and maybe hit above 600 horses
#9 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
and the ABS sensors are no problem, you jsut have ABS rings pressed on the new axles, and get the GT ABS sensors and wires. costs a whole extra $100 to do all that
#10 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
#11 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
all that needs to be done is when you do a clutch upgrade to a 26 spline input shaft so you can guarantee that weak 10 spline will never snap. pretty easy mod, jsut pull the front cover of the trans, and it takes a few times getting the shims right with your backlash guage, and your done, and have a tranny that will holld 1000RWHP pretty much.
yeah i know about that stuff remember i rebuild em..but yeah i thought maybe getting a turbo setup just to hit 600 but to much money..what numbers you putting down as of right now king chronic??
Gun Whore
04 Whipple Cobra
10.61@129.96
it still needs a couple things to finish it up, but im looking for at 620-640RWHP pump gas 660ish pump gas + torco and more aggressive tune, and hopefully near 700RWHp with high boost, and race gas.
03 10th Ani Cobra Vert
12.20@115
You might as well put the kenne Bell on it... more potential in the future... and we all know once you start modding you car it never ends...
#15 | |
2003 Sonic Blue Mustang GT Steeda cold air intake Bassani off-road x-pipe Magnapacks Steeda Tri-Ax Shifter |
KB'd GT
I'd say you are wasting your time shooting for 550 with the stock heaton unless you add a nice dose of giggle gas. I think it may be done on boost alone, but not for $2500.
well i have my laughing gas ready anyways to go in it..but its only if i need it lol..
termi
doesnt SLP sell a kit that says itll make about that or a little more for less then 2500
2003 Mach 1, 5 speed ![]() U.S. Army - 11B "And on the 8th day god created the infantry and all hell stood at attention" |
slp
SLP Performance Parts - VIEW P/N: M31050, this says itll give you 575 but its 2800, prob get it for less if you just buy MAC headers, and stuff, not promising anything but that says itll give you 575 but thats prob at the motor not the wheels
#20 | |
KB'd GT
Threads Similar to: how much horsepower from a termi??
| termi killer..... | White Thunder | The Clubhouse | 0 | November 30th, 2007 02:33 PM |
| WRX vs Termi | 9cobra3 | Modular Mustangs | 21 | November 14th, 2007 12:41 PM |
| 03-04 termi spoiler on my car? | tjames | Visual | 4 | November 5th, 2007 06:10 PM |
| Cobra vs Termi | AnglicoGT98 | 99-04 | 30 | November 1st, 2007 08:53 PM |
