Question about X3 tuner
Old January 11th, 2008, 06:20 PM   #1
TweederGT03 is on a distinguished road
I have gears going in tuesday and already have an x3 to flash the computer with. When I ordered it they ask what gear ratio you run and I said 4.10's. When I put the tune in the car do I still have to go back through the menu to change gear ratio or does the canned tune already adjust for that gear size. Second question, since it is a canned tune, when I add a cai is the tune still ok or do i need a costum tune? The car is basically stock except for exhaust. Thanks in advance.
Old January 11th, 2008, 06:28 PM   #2
Trick Tuners's Avatar
KB'd GT
You should always check the fuel trims to see how close the tune is. If they are + - 7% you should be ok. If you told your tuner 4.10 then it should be set on 4.10 without you changing anything. More info here.
Threads Similar to: Question about X3 tuner
SCT Tuner Question 98gt760 96-98 2 December 30th, 2007 10:07 PM
Tuner Question Xantho99 99-04 1 November 29th, 2007 12:08 PM
Tuner Question/Help. TheUNZippee! 2005 - 2010 31 May 26th, 2007 11:47 AM
tuner question 02steedagt Modular Mustangs 5 April 10th, 2007 07:07 PM
yet another tuner question..... MyLittlePony 2005 - 2010 10 March 8th, 2007 07:13 PM
