Discussing chip ? in the 99-04 Forum. so i have searched all over the net, and this sight. But cant find what ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
03 gt vert
lights cant time it
chip ?
NX EFI plate 250 jetcustom tune Eibach Pro-Kit Magnaflow cat back high flow cats, 3:55s, ported and polished heads, comp cams, forged pistons/ rods Curently building up 03 mach block w stage 3 port job. look for twins and more n2o |
03 gt vert
lights cant time it
no i cant use that because it says it will only go up to 100 shot i was going to buy it but i cant find any one who can tell me how to tune it for a 150 shot
03 gt vert
lights cant time it
maybe i am reading it wrong though
you should still be able to get it and take it to an SCT tuner in your area and have them write you a tune for a 150 shot of spray. the way i read it, AM can write you a tune, but only up to 100hp...
![]() Submariners Do It Deeper |
2003 Mach 1
You just can't get a sight unseen tune for more than a 100 shot. It is to cover their asses. The eliminator chip is what I ordered. If you are gonna run a 150 shot you will have to go to the dyno to get them to do it. Or you can just run 2 stage colder plugs and see if that gets you in the range you want. their mail order 100 shot will most likely be safe enough just to run 2 stage colder plugs and be good. But I wouldn't bet my motor on it.
Under Construction Project N/A 4V Under Way Rep is always welcome |
03 gt vert
lights cant time it
ok cool ill call them before i order it
Authorized Vendor
KB'd GT
Yeah, 150 is a big shot and is best tuned on the dyno. Is the fuel system up to the task, or did you add a small nitrous fuel cell for a wet shot?
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX wideband products @ Trick Tuners email joe@tricktuners.com PM for super MM member deals! |
03 gt vert
lights cant time it
i have a wet shot kit
Authorized Vendor
KB'd GT
Running a big wet shot on a returnless fuel system is a BAD idea unless you have a dedicated nitrous fuel system. No decent tuner will attempt to tune it. There will be a huge lean spike as the nitrous hits and sucks the fuel rail dry before the fuel pump can catch up. Wet kits work much better on return style cars, or even better yet with a dedicated fuel cell.
#11 | |
2003 Mach 1
That is partly true. The key is to know your fuel pump load under wot, and keep an eye on the AFR. If you are gonna run a big shot, think about tapping the fuel line before the pressure regulator and putting a independent regulated line to the fuel solenoid. People run 150 shots on stock rails with the nitrous tapped of the schrader valve all the time. you just need to keep an eye on the AFR. Running a 150 shot and doing some bolt ons you are gonna need a pump before you know it so just plan on that.
Authorized Vendor
KB'd GT
The problem is returnless cars have no regulator and its all controlled by a feedback loop between the FRPS and the pump. It does not react quick enough for the initial hit and they get "confused" when you suck out an extra 20-30% without the ECU expecting it. If you tap off the fuel rail on a return style car its no big deal because the regulator can add fuel nearly instantly and the fuel pump does not change its operation at all.
2003 Mach 1
Yea we have a regulator. its right before the fuel rail.
Threads Similar to: chip ?
| Which chip should I get? | Rutcutter | 5.0 Mustangs | 10 | June 19th, 2007 07:36 PM |
| SCT chip???? | 95blackbeauty | 94-95 | 1 | March 15th, 2007 10:47 PM |
| HP Chip | mustang1072 | V6 Mustangs | 14 | January 24th, 2007 12:45 PM |
| ? (Chip for 95 GT) | new 5.0 | 5.0 Mustangs | 11 | December 16th, 2006 10:29 PM |
| Chip | Mkenne4@tampabay.rr.com | V6 Mustangs | 4 | December 13th, 2006 09:05 PM |
