quick question guys.
Old January 12th, 2008, 05:04 PM   #1
natedawgishot's Avatar
natedawgishot is on a distinguished road
ok i just dropped a new motor in my gt and now about 1000 miles later it started ticking from where the fly wheel and the torque converter hook up. i mean loud as hell but its not from the motor or the tranny...so does any1 know if the torque converter can tick loud as hell. any ideas guys? thanks
2000 gt convert and a 2001 v6
Old January 12th, 2008, 05:06 PM   #2
Moderator
Take the inspection cover off, and double check the flywheel bolts.
Old January 12th, 2008, 05:09 PM   #3
Mustang RacR94's Avatar
03 mach 1
13.2@109
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
ticking
when the exhaust was put back on, was everything put together right, sounds like an exhaust leak, but if it started happening after 1000 miles, sounds like it could be from where the mid pipe meets up with the header, i do beleive theres a gasket that goes there, and if someone put it on wrong or reused the old one it couldve blown out and that would cause a very loud ticking, besides that i cant really think of anything else
2003 Mach 1, 5 speed
U.S. Army - 11B
"And on the 8th day god created the infantry and all hell stood at attention"
Old January 12th, 2008, 05:15 PM   #4
ok i just took off my torque converter and there are shavings of metal in there so damn it...anyone know where to get a converter?
Old January 12th, 2008, 05:17 PM   #5
Moderator
Sounds like a bolt backed off and was hitting the bellhousing or something. Is the converter fubarred?
If you need one, you can check these places:
Mustang Parts & Performance - American Muscle
Lethal Performance, Performance Parts for Ford Mustangs, Cobras, Chevy Corvette C6, LS1
Livernois Motorsports - Home Page
Old January 12th, 2008, 08:54 PM   #6
03 mach 1
13.2@109
torque converter
well hell i was totally wrong lol, never owned a auto car maybe thats why
U.S. Army - 11B
Old January 12th, 2008, 10:27 PM   #7
mattstang's Avatar
mattstang will become famous soon enoughmattstang will become famous soon enough
Send a message via AIM to mattstang
+1
Performance Automatic
try here too
if your going for straight line performance you should get a higher stall speed. contact a company like pa and they can reccomend a speed for ya. also if your gonna use n2o you might wanna get one with ballon plates.
FX4 Crew
Crew member #3
Old January 12th, 2008, 10:46 PM   #8
tom2000r is on a distinguished road
If bolts are loose replace them and use blue loctite..
Old January 13th, 2008, 04:40 AM   #9
well i have to get a new one so will i even see a difference if i add a preformance new torque converter?i have an automatic?
Old January 13th, 2008, 04:54 AM   #10
X2RTION GT's Avatar
02 GT
X2RTION GT is on a distinguished road
yes you will launch at a higher rpm than 1500 depending on wich one you get
and yes you do have an automatic
Old January 13th, 2008, 12:41 PM   #11
finaly03vert's Avatar
03 gt vert
lights cant time it
finaly03vert is on a distinguished road
do not put a stock one back in there is a night and day diff between them
NX EFI plate 250 jetcustom tune Eibach Pro-Kit Magnaflow cat back high flow cats, 3:55s, ported and polished heads, comp cams, forged pistons/ rods
Curently building up 03 mach block w stage 3 port job. look for twins and more n2o
Old January 13th, 2008, 05:10 PM   #12
so will i see a faster 1/4 mile time?
Old January 13th, 2008, 06:03 PM   #13
mattstang's Avatar
not neccesarily mph but your e.t. wil improve
FX4 Crew
Crew member #3
Old January 13th, 2008, 09:45 PM   #14
what is e.t? and will a torque converter with a 2400 whole shot make me have to idle at a higher rmp?
Old January 13th, 2008, 10:06 PM   #15
mattstang's Avatar
et = elapsed time. your time across the track
you wont idle higher just when you leave a stoplight or whatever your car will rev a lil higher before it gets goin.
FX4 Crew
Crew member #3
Old January 14th, 2008, 04:21 AM   #16
X2RTION GT's Avatar
02 GT
whaatt
r u sure i thought it only stalled at a higher rpm when pressing the brake n gas at the same time(before the tires start spinning)
cuz if it revs higher at a stop to get going wont that make it shoot out everytime? even if youre not trying to... that would suck
Threads Similar to: quick question guys.
Turbo Stang Guys Quick Question? e3sean 5.0 Mustangs 1 November 21st, 2007 04:43 PM
Really Quick Question Guys (Speed Trailers) Fastback91 96-98 9 November 14th, 2007 01:03 AM
quick question Reggedon 99-04 10 October 21st, 2007 05:08 PM
Quick Question. Help quick. john0315 5.0 Mustangs 7 April 7th, 2007 05:33 PM
quick question for an '06 tsp_2177 V6 Mustangs 0 March 23rd, 2007 06:43 PM
