Schrader Valve
Old January 13th, 2008, 10:04 AM   #1
1965 Ford Mustang
01dutchGT is on a distinguished road
Send a message via AIM to 01dutchGT Send a message via Yahoo to 01dutchGT
Schrader Valve
Im trying to install my Fuel Pressure gauge but cant fine it. Anyone have a pictures or can explain better
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old January 13th, 2008, 11:37 AM   #2
finaly03vert's Avatar
03 gt vert
lights cant time it
finaly03vert is on a distinguished road
it is the valve that is on the end of the pass fuel rail. it shood have a small black cap on it but that cold have come off, if not it looks like it is ready for a hose fitting
NX EFI plate 250 jetcustom tune Eibach Pro-Kit Magnaflow cat back high flow cats, 3:55s, ported and polished heads, comp cams, forged pistons/ rods
Curently building up 03 mach block w stage 3 port job. look for twins and more n2o
Old January 13th, 2008, 11:55 AM   #3
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
You see where the braided hose with the red fitting is connected to? That's where your schrader valve is.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old January 13th, 2008, 11:57 AM   #4
03 gt vert
lights cant time it
lol yours has a red hose as well wonder what that could be
Old January 13th, 2008, 12:05 PM   #5
03 R Code's Avatar
That is an old pic... but it used to be for a nitrous kit
Old January 13th, 2008, 12:15 PM   #6
Proud American
MustangMatt96GT's Avatar
Im installing a nitrous kit today. BUt the garage is so cold, i dont want to jack up the car and crawl on the cold concrete to run the nitrous line.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old January 13th, 2008, 01:54 PM   #7
03 R Code's Avatar
put down some cardboard... That's what I did when I installed mine, except it was because the asphalt in the parking lot was hot!
Old January 13th, 2008, 09:21 PM   #8
rays03gt is on a distinguished road
dutch not all stangs have a shrader valve. mines an 03 and dose have one. but I was told not all stangs do. I just don't know what years. This means you'll have to tap your fuel rail.
Old January 13th, 2008, 09:23 PM   #9
1965 Ford Mustang
i found it finally. Now i just have to wire it. It was right in front of me and i just missed it. Just need to figure out the wire now
1965 Mustang
Old January 13th, 2008, 09:25 PM   #10
glad u found it dutch. taping the fuel rail woulda sucked!
Old January 13th, 2008, 10:07 PM   #11
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
You can drive down to my house. It's about 80 degrees with a moderate breeze- excellent.
Old January 13th, 2008, 10:08 PM   #12
Proud American
cant drive
i broke my schrader valve
anyway anybody local want to help you are more than welcome too
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old January 13th, 2008, 10:09 PM   #13
MM's Mad Scientist
acmillr's Avatar
Slow Fella
cant drive
If nothing else, I have a pair of rails I can send you.
Old January 13th, 2008, 10:13 PM   #14
Proud American
I got the part out of the rail, so I just have to get an adapter. Im going to grab it tomorrow after school!
Thanks though!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old January 13th, 2008, 11:23 PM   #15
1965 Ford Mustang
Im really wanting nitrous on my car just to have in case someone is alittle to cocky. I can purge it off and if they still want to go, spray his ass down. Question is, should i get it tuned before or after it becaue after tax returns are in my stage 2 heads and stage 2 cams are going in and will have to be tuned.
1965 Mustang
Threads Similar to: Schrader Valve
Fuel Rail Schrader Valve thread MustangMatt96GT 99-04 5 January 5th, 2008 12:35 AM
Schrader valve... fuel rails? flattusmaximus78 General Tech 3 June 4th, 2007 05:06 PM
Schrader valve... fuel rails? flattusmaximus78 V6 Mustangs 2 June 3rd, 2007 09:42 AM
new egr valve mikethetigerrr V6 Mustangs 9 April 29th, 2007 02:12 PM
PCV valve 83 5.0 5.0 Mustangs 3 November 13th, 2006 09:32 PM
