Discussing Teksid Build in the 99-04 Forum. Hey guys I've been kicking around the idea of doing an all motor build ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Teksid Build
Flowmaster 40's, BBK O/R X pipe, PP, 75mm TB and UI Plenum, BBK CAI, Diablo Sport Tuner, And 4.10's |
04 Whipple Cobra
Fuckin Fast
just make sure its one from a cobra, the lincoln teksids vary slightly, and are not as good as the cobra.
look under the intake manifold into the intake valley of the block, if its a teksid, it will have a squared grid pattern, if its a WAP, it will have a damond grid patternl
04 Torch Red Cobra #456 of 3768 born on 11/21/03 |
oh man this one is a 93 lincoln....so its not as good?? damnit now im bummed out haha i thought this was gonna be a good deal
04 Whipple Cobra
Fuckin Fast
ill try to find what the difference's are between the cobra and the lincoln.
300 is also kinda high, for about $350 you can get a 99 cobra shortblock which will have the cobra froged crank you can use, aswell as the teksid block. on 99/01 cobra though you have to check the grid pattern and make sure its a teksid, some of them had WAP's.
98 Mustang GT
12.85
The block is the exact same block between the MK VIII and the Cobra. There are other differences, but the block is the same. The crank definitely is not, but I wouldn't use that heavy Cobra crank on an naturally aspirated setup anyway.
Also, I thought $300 is a fine price. Just my opinion though. I mean, he is getting that with no shipping costs involved and that makes a difference. If it was me, it was in good shape and I wanted it, I woudl buy it. But that's just me. Darrin |
Editor
Secret In The Works
Okay, theres definately some mis-information here. Mark VIII's from 93-98 all used the Teksid block. Its exactly identical to the 96-98 cobra blocks. The heads, are also the same. The intakes vary, as does the fuel system, and cams. In general, the blocks are the exact same. Pull the intake off, and look in the valley.. if you see 6 large structural ribs horizontally... its a Teksid. If you see 10 smaller ribs, its a WAP. Theres a 99% chance its a Teksid if the car hasnt been jacked with. If the block is in good condition, thats a steal at 300 bucks.
Definition of Fast? ![]() I'd say thats good enough. ![]() NMRA Outlaw 10.5 Season Opener 2008 Photo courtesy of - Yours Truly |
#7 | |
Editor
Secret In The Works
its a good deal man, you should get it and forge the internals. you'd be able to handle almost as much boost as you can possibly throw at it. I would definitely guess that it is a teksid. For 300 bucks its a pretty good deal. I would listen to the guy with editor under his avatar before many of the other people on here who give misinformation quite frequently
Next question. If I build this primarily for N/a but ...on down the road I decide...hmmm maybe i need FI.. Which compression ratio would be versatile for both.
i'd definately keep it under 10:1 if you ever plan to go with any kind of boost
Is 10:1 ideal or...below 10:1 you mean...
below 10:1 i believe is a safe bet
Editor
Secret In The Works
You could get away with 10:1 for N/A now, and down the road run a centrifugal supercharger. The Mach 1 guys do it all the time. If your planning on turbocharging, 10:1 is definately high for a street engine.
hehe its a go...they are yanking it out and i am gonna get it friday....$250.00 i talked them down a little im so pumped. A friend of mine works at a big machine shop so hes gonna take care of all the block work....but now anyone know where i can find a cheap cobra crank next part of the build!
Threads Similar to: Teksid Build
| Build It Or Buy It | mrgt | 99-04 | 13 | December 19th, 2007 05:35 AM |
| If you build it......he will come | bossman2kgt | Videos | 2 | November 15th, 2007 09:34 PM |
| 408 build | Iownastang | 5.0 Mustangs | 49 | October 14th, 2007 10:09 PM |
| 302 Build | 83five0 | Engine | 4 | September 30th, 2007 02:17 PM |
| 01 GT build | WAR-PARTY | Pictures | 5 | July 15th, 2007 12:25 PM |
