Gears and horsepower
Old January 15th, 2008, 01:38 PM   #1
NMR-2vGT's Avatar
1996 GT
Too Slow....
NMR-2vGT will become famous soon enough
Send a message via AIM to NMR-2vGT Send a message via MSN to NMR-2vGT
Stupid question but im being told something and i dont think its right. Do gears affect your final horsepower number or not?
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
MM Unite For Bubba
Old January 15th, 2008, 01:40 PM   #2
03 10th Ani Cobra Vert
12.20@115
Montanasvt is on a distinguished road
I heard the higher gear ratio the lower your horsepower...but it doesnt make since to me
Old January 15th, 2008, 01:43 PM   #3
NMR-2vGT's Avatar
1996 GT
Too Slow....
^Any truth to that? Ive always been told they dont affect hp. just how fast you get through the power band basically.
MM Unite For Bubba
Old January 15th, 2008, 01:46 PM   #4
Gun Whore
04 Whipple Cobra
10.61@129.96
KingChronic will become famous soon enoughKingChronic will become famous soon enough
they dont really affect HP, but with a bigger gear, it will read less power, not much though 2-10RWHP typically. you can lose that much though just by it going form say 60 degrees to 70 degrees.
Modded Mustangs Make-A-Wish for Bubba "BWAL09"
[url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url]
[QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE]
Old January 15th, 2008, 01:49 PM   #5
NMR-2vGT's Avatar
1996 GT
Too Slow....
Ok, b/c i thought they didnt do much at all and people on another forum are saying that gears do affect horsepower. (Which i guess is somewhat right) But its not really that noticable is what your saying
MM Unite For Bubba
Old January 15th, 2008, 01:49 PM   #6
MU71L4710N is on a distinguished road
yes taller gear will read slightly less horsepower on an average dyno because its under the assmption of a 1:1 ratio in 4th gear stock. you arent loosing any horsepower though, its just not reading all of it on a dyno. a mustang dyno can be calibrated to know you have different gears and it will read your real number.
Old January 15th, 2008, 01:55 PM   #7
Gun Whore
04 Whipple Cobra
10.61@129.96
^^ exactly, you dont actually lose power, it just reads a little less, and not much at all.
gears are definently one of the best single mods you can do
Old January 15th, 2008, 03:25 PM   #8
NMR-2vGT's Avatar
1996 GT
Too Slow....
Ok, bc someone was trying to tell me actually lose hp with a taller gear and that went against everything ive ever been told. But i didnt know about the dyno reading lower bc of it so thats good to know. Thanks
MM Unite For Bubba
Old January 15th, 2008, 04:21 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Gearing, tire type and roller position can manipulate chassis dyno numbers. Big deal. Chassis dynos are tuning devices at best. Real horsepower is measured at the flywheel.
Old January 15th, 2008, 05:13 PM   #10
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
Originally Posted by Darrell View Post
Gearing, tire type and roller position can manipulate chassis dyno numbers. Big deal. Chassis dynos are tuning devices at best. Real horsepower is measured at the front wheels.
fix'd
Old January 15th, 2008, 05:19 PM   #11
Gun Whore
04 Whipple Cobra
10.61@129.96
exactly, shit, lowering your tire pressure will reduce your dyno numbers.
its nice to have a high dyno number, but it isnt everything, how it puts it to the ground, suspension setup, and driver skill is.
dyno numbers are for bench racers IMO.
if you want high numbers, get a big 28" tall tire, and air it up like crazy, get smaller gears, fill the radiator with water only, use thinner oil, hose down the IC, and/or radiator with nitrous, put a fan blowing air right over the intake, and go to the dyno on a 50-60 degree day with no humidity, at a place close to sea level.
if you want to go fast, get bigger gears, the properly sized tire, and run.
Threads Similar to: Gears and horsepower
Horsepower Sanitarium8889 96-98 38 December 15th, 2007 01:47 AM
347 horsepower? 89COUPE 5.0 Mustangs 7 September 7th, 2007 08:36 AM
how much horsepower? maddymac07 99-04 5 March 11th, 2007 09:47 PM
Horsepower Mkenne4@tampabay.rr.com V6 Mustangs 8 December 29th, 2006 10:00 AM
