How hard of an install??
Old January 17th, 2008, 10:53 AM   #1
AnglicoGT98 is on a distinguished road
Send a message via AIM to AnglicoGT98
I was going to put an Afco heat exchanger and a 2.80 pulley and new idler pulley in. Anyone have any experience with these and how hard is the install. The shop wantes to charge about $250 just for install for both. Should/can I do it my self??
Old January 17th, 2008, 10:53 AM   #2
HMUSN's Avatar
iTrader: 9 reviews
the HE is simple.
you would need a puller for the pulley though
Old January 17th, 2008, 10:57 AM   #3
Is the HE just a simple, unbolt old...then bolt up new?? I don't mind having them do the pulley. I don't want to screw it up. And I also don't have the puller.
Old January 17th, 2008, 10:59 AM   #4
HMUSN's Avatar
iTrader: 9 reviews
Lethal Performance/ AFCO GT500 Pro-Series Dual Pass Heat Exchanger Install with Pics! | Lethal Performance GT500 Blog
basically the same install
Old January 17th, 2008, 11:18 AM   #5
Doc you are the best! I'm going to go buy one right now and put it in.
Old January 17th, 2008, 11:19 AM   #6
HMUSN's Avatar
iTrader: 9 reviews
good luck man.
Old January 17th, 2008, 11:25 AM   #7
One more question...
Just so I'm understanding right...to flush the intercooler I just pump a bunch of water through it, let it all drain out. Then I mix the water wetter with more water and refill??
Are you suppossed to mix those 2 togehter before you put it in??
Old January 17th, 2008, 11:27 AM   #8
Mustang RacR94's Avatar
03 mach 1
13.2@109
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
both are pretty easy task, the pulleys are easy if you have the tool, i beleive some companys give you a puller with the pulley
2003 Mach 1, 5 speed
U.S. Army - 11B
"And on the 8th day god created the infantry and all hell stood at attention"
Old January 17th, 2008, 11:32 AM   #9
Everywhere I've seen you have to buy it so far. I think I could probably do the pullies but for the amount it would cost me to buy the tool and then the time to do it. The shop is only charging $80 to do it so I don't think it's too bad.
Old January 17th, 2008, 11:38 AM   #10
03 mach 1
13.2@109
did you check americanmuscle.com or possibly even steeda.com im sure they might offer the tool with it, but i could be wrong ive never gone and looked at one since i dont have the use for it myself
U.S. Army - 11B
Old January 17th, 2008, 12:27 PM   #11
Gun Whore
KingChronic's Avatar
04 Whipple Cobra
10.61@129.96
KingChronic will become famous soon enoughKingChronic will become famous soon enough
the HE, and idler are both very simple installs, and the pulley is too if you have a the correct eaton pulley puller
first off, dont get the AFCO, there are plenty of people having problems with them leaking, and they also dont have as big of a surface area as gords, or LFP. the gords however is i beleave about $400-500, so ive used a LFP dual pass on both of my cars with great success, its probably the highest recommended out there
LFP Extreme Dual Pass Intercooler Heat Exchanger 2003-04 Cobra [LFPDualHeat] - $289.95 : Lightning Force Performance
then as far as pulley, billetflow is the only way to go for both pulley's, and idlers, and the quality, and ease of swapping pulleys afterwards is simply amazing.
you can order strait from billetflow, and they also have a loaner puller they rent to you for $50, then you ship it to the next person that needs it. billetflow also makes the best idlers you can buy too.
BilletFlow: Home of Premium Billet Pulleys, Throttle Bodies and Accessories
they can also be purchased from
Lethal Performance, Performance Parts for Ford Mustangs, Cobras, Chevy Corvette C6, LS1
Modded Mustangs Make-A-Wish for Bubba "BWAL09"
http://www.moddedmustangs.com/forums...ite-bubba.html
Originally Posted by Drgnracin72 View Post
please do this country a favor and go play tag football with an oncoming car
Old January 17th, 2008, 12:28 PM   #12
Gun Whore
04 Whipple Cobra
10.61@129.96
and most shops only charge about $40 to change a pulley BTW. im also sure somebody in your area will have a pulley tool
Old January 17th, 2008, 12:50 PM   #13
Too Legit to Quit
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
make sure to get that bitch tuned aswell
Old January 17th, 2008, 12:50 PM   #14
Gun Whore
04 Whipple Cobra
10.61@129.96
+1. a mail order will be more than fine for just a pulley
Old January 24th, 2008, 11:37 PM   #15
12' Boss, 11' GT, 10' 500
Jared@Lethal is on a distinguished road
I believe you're a bit confused and only want to make sure people get the right information so they can make the right decision. There are no problems with the AFCO Dual Pass. They are by far the highest quality Dual pass as well as the first dual pass for the 03-04 Cobra that was released to the market. AFCO is a company that specializes in cooling products. They've been around way longer than most. You'll find that most others selling a dual pass actually copied AFCO's design which is why at this time the AFCO Dual Pass for the Shelby is the only Dual Pass available. Let's see who copies it and then sells that design next. Not the innovator but the copier. Out of the hundreds of AFCO Heat Exchangers we've sold I've never received one back. Not 1!
The only reason the LFP's is recommended is because of the price. They undercut the AFCO's pricing to take the business away. Copy something and sell it for less isn't too unfamiliar in the parts industry for some. Jared
Threads Similar to: How hard of an install??
How Hard To Install Tranny outlawedstang 99-04 21 December 7th, 2007 10:14 AM
how hard would it be? AFtriathlete 99-04 13 September 19th, 2007 05:14 PM
Hard to please WAR-PARTY The Clubhouse 40 August 15th, 2007 12:58 AM
How hard would this be? Cricket 99-04 10 May 30th, 2007 02:08 PM
Is a CAI hard to install? Compy386 V6 Mustangs 19 January 30th, 2007 05:20 AM
