2003 Mustang GT
Tire psi?
does the tire psi really make that much of a difference?
my PSI is kinda off by like 3 psi on my right tire, Just wanted 2 know so i can run at my optimum level |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
it all sepends on some factors. size, tire type, what you are doing with it, etc. street tires are made to run at a warm temp, too hot and they become oily and slick. contact patch needs to be optimum, too low psi there will be cupping isues, too high psi and the contact patch wont be even all the way across. there are a lot more factors, but this is a start.
2003 Mustang GT
18" Nd i have SUMITOMO Tires 275 ZR, whats the optimum psi..4 the best traction and optimum performance
KB'd GT
Read the tire. I usually go for about 5psi less than max for regular driving. Dropping a some psi can help the tire hook a little better, but will be more squirmy in the corners.
on highway i put all mine all at 32 when i get home i put my rear nittos down to 22
mm's nitrous mod
2000 mustang gt
i run 27psi in my rear tires all the time. i dont really have any stability issues.
Proud American
I drove home once on the slicks at 14 PSI. That was fun!
N/A 4v Guru
2003 Mach 1
27-32 is what I shoot for on mine. usualy all of em are at 28-29. You don't want a 5psi or more difference between tires. put em all the same. Tire pressure directly affects fuel mileage,tire wear,grip,and stability.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
03 10th Ani Cobra Vert
12.20@115
i have always ran 35 in all my vehicles...
2003 Mustang GT
35 Sounds Nice, i dont really want to have too much wear and tear on my tires, they were freaking 260 bucks each..Ouch..=( lol
Threads Similar to: Tire psi?
| more tire help.. | 92stang0802 | V6 Mustangs | 1 | December 30th, 2007 01:49 AM |
| Tire Rub | randy759 | 99-04 | 10 | December 29th, 2007 07:38 PM |
| Tire | burin_rubber | V6 Mustangs | 38 | November 28th, 2007 06:28 PM |
| Tire Help... | Onemanzu | The Clubhouse | 29 | October 13th, 2007 06:28 PM |
| Tire and rim help | hubba076 | 99-04 | 20 | July 10th, 2007 03:46 PM |
