Need Help Please, Ignition Or Fuel Problems?
Heres my problem my car breaks up real bad at about 2800 rpm sounds like crap then levels out after that. I had 19lb injectors when my new engine was assembled. Then I had it dyno tuned and 30lb injectors installed and still the same problem. I had TR6's in with the 19lb injectors and then TR55's with the 30lb. injectors. Took those out and put in Autolite Platinums and no change.
Could it be a backpressure problem or lack thereof? I've got longtubes w/slp x-pipe,freeflowing cats and loudmouth II's catback. Before the new engine build and without the longtubes the car ran fine. I'm stumped! FYI I have an 02 GT n/a with 10.5:1 forged internals,bigcams,ported heads,long tubes,75mm tb & plenum,30lb injectors,3000 stall,4.10's Any ideas would be GREATLY Appreciated. |
Threads Similar to: Need Help Please, Ignition Or Fuel Problems?
| HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? | 1slowhatch | 5.0 Mustangs | 0 | April 21st, 2007 07:48 PM |
| Ignition problems? | tim si | 5.0 Mustangs | 18 | April 14th, 2007 12:41 PM |
| Ignition problems | willdabeast | 96-98 | 12 | February 20th, 2007 07:00 PM |
| Fuel Pump problems | petro68 | 5.0 Mustangs | 5 | August 24th, 2006 07:12 PM |
