I picked up a built shortblock to start.
Forged stroker motor
-ARP Main Studs
-ARP 2000 Rod Bolts
-ARP Side Bolts
-Forged Kellog Stroker Crank (3.75")
-Forged Manley H Beams
-Forged Manley Platinum Series Pistons(-23cc Dish)
-Manley Steel Rings
-ARP Pro Series Headstuds.
-Balanced Rotating assembly
-Clevite bearings throughout the motor.
-Block was bored .020 to 3.572
-MMR oil pan
-Melling oil pump
After UPS delivering my package to the wrong address, I received my parts 3 days after UPS said it was delivered.
Got trickflow track heat 44cc heads, MMR stage 3 turbo cams, all my timing components, lifters, rockers, and head gaskets.
The heads are dead sexy....
There are still alot of odds and ends I need, but I'm planning on getting the heads installed this week.
I get lost for words when I hear someone say they didn't degree the cams or someone recommended they did not. This is one of the absolute most important steps of a build. This is the part that times your entire rotating assembly and ensure everything is in the right spot at the right time.
Lets step back and get you squared away with this whole degree business.
I have the exact same cams and it calls for 111* intake center line.
Again I had to retard 6* left bank and 4* right bank.
That means without degreeing them they were at 105* intake center line on right bank and 107* on the left. Dont think his engine would be too happy at those center lines.
Single turbo setup with only 1 38mm wastgate will put way more pressure on the exhaust valve spring than the same setup running 2 38mm wastgates or a larger single gate. Single small gate will require more seat pressure on the exhaust valve spring.
There's a reason they sell them with the 150lb springs. This issue is turbo related. The other power adders dont need the extra seat pressure
Well I at least checked the cam base to rocker clearance today and everything was good there. I guess I'll be ordering a degree wheel to at least see how it looks. I know to squeeze every last thing out of it, I needed to degree. As I said, when my tuner said not to bother, I didn't fight it. You'd think if the TFS heads move the centerline and screw up the timing, that they would tell you to use adjustable gears. Hell the instructions that come with them show stock cam gears. I'll order a degree wheel tomorrow and go from there I guess.... thanks for the input fellas.
Ok gents,
So I think I may be screwing something up here in this degree process. Does it matter that I used a Mr. Gasket degree wheel that is in quarters?
So looking at this, (the edge of the plate being the "pointer") I counted it as 171*. Because the one on the MHS site goes to 180. Regardless, I did the process a few times and continued to get ~160 after adding and dividing by 2. Now it varied a few degrees as I repeated the process and got TDC again.
Here is the valve at maximum lift, zeroed the dial.
Here is how far the dial is already turned when I get to maximum lift.
At .050
Next time I hit it after passing the 0
This was the last time I did it and the pointer is slightly further away than the first couple times. (the last time the wheel turned a bit when tightening the crank bolt so i adjusted the pointer to make up for it, but it moved it further from the wheel due to the angle) I know I can definitely fab up a better pointer, but I just wanted to see how close I was and being around 160 seems like something is F'd up. So just to be sure I didn't screw the pooch from the beginning, I rotated the motor until the dots and colored links lined up again.
What am I missing here guys? Am I screwing up the process somehow? Hopefully I'm making a stupid mistake. I didn't even touch the other side tonight. Wanted to figure this out first.
OK so I might be an idiot. I think I figured out at least one way I screwed up. Once you zero out the dial on max valve lift, then you rotate the crank back (counterclockwise) for your "before zero measurement correct? Then back forwards for the after zero measurement. It didn't dawn on me until reading another how to on degreeing. I wasn't finding centerline at all because I was rotating clockwise the whole time. So both my readings were as the valve was closing. I'll redo it tonight when I get off work and hopefully have better results....
Correct. When you turn it counter clockwise make sure you go past .050 a little bit. Then turn it back clockwise to read the .050 timing mark. That is to keep the chain tight to get the correct reading.
This tool is ready handy. Allows you to keep the timing wheel tight and makes turning engine easy without worrying about the timing wheel moving. http://www.summitracing.com/parts/PRO-67491/
Alright so I think I got this figured out. My RH cam is actually pretty much where I want it at 112*. My left on the other hand is coming in at 106-107. So I'm good with the RH one, just need to retard the LH about 4*. I'm contemplating grinding the keyway off a bit to achieve this, since I dont need to mess with the RH. Unless someone has a good reason why I shouldn't? I've read some people actually prefer this method because its less prone to fail. Thoughts?
---------- Post added at 04:40 PM ---------- Previous post was at 03:48 PM ----------
So as I rotate, i know its semi normal to have some chain slack since I don't have oil pressure, however is this much normal?
This happens at a particular location in each revolution. Then at a certain spot the tensioner will expand and all will look normal again. As it sits in the picture, the side of the chain with the tensioner is very tight. I wasn't really concerned with it, just figured I'd mention. Maybe just the way the lobes are at that spot pulling the cam?
Your fine, I was worried about the same thing with the slack at a certain area with my car as well but it'll go away once oil pressure goes through the tensioner.
That's correct. Its what the MMR timing set came with. Didn't get as much done today as I'd hoped, but I did get the timing close. Took forever until I nutted up and just hit it with a tungsten cutter and my dremel. Ended up getting the LH to 110.5. So its about 1.5 degrees off from the RH, bit way closer than it was. Thanks to all for the help so far.
Haven't got too much done this week so far. I did wire up my line lock. I got the SLP kit, but immediately was unsatisfied with the cheapo looking toggle switch it came with. Plus the instruction that come with it have you wire the solenoid straight to power and your switch controls ground. Not a big fan of doing it that way, so I went power to switch, then the switch controls power to the solenoid and the only constant on the solenoid itself it ground. Any who....
I de pinned the convertible switch plug for power just out of convenience.
And this is the new switch I got for it, nothing fancy but looks alot better than the one that comes with the kit.
I plan to mount the solenoid tonight
So for Christmas the wifey decided to buy me a new e-brake boot. Mine was torn and it bugged me. I figured I'd replace that while the car was apart. It was a pita. The instructions that came with the boot said to glue it on. Naturally I didn't want to do that. The stock one is just stapled, well I tried that, but i don't have a heavy duty stapler and the typical office stapler that I do have was not up to the challenge. I ended up drilling numerous small holes and weaving safety wire through it to hold it. It was tedious, but turned out ok.
---------- Post added at 08:47 AM ---------- Previous post was at 08:34 AM ----------
Now I'm on the hunt for trannys, I've contacted promotion, liberty, and hanlon. They all seem to be similar price points for a similar product. I want to stay with a 3650 at this point, but there is not much point on me spending money on a good 10 spline clutch if I'm just going to snap the input as soon as I launch. So at a minimum I want a 26 spline upgrade, shitty thing is I'm in WA and those shops are in like FL, Michigan, and PA i think so with shipping I'm debating if i should just eat the core price and sell my trans outright. I did find a used promotion one for 2k with a fidanza clutch, but i didn't jump on it because I don't want a puck clutch if i can avoid it. Kinda wish I had just bought it.
Alright so I got some walbro 465s and a division X hat on the way. Plan on ordering my rails and reg tomorrow. Going with an -8 feed and return. Using Aeroquip -8 ST-W line. (teflon) So today while waiting for the parts I decided to start the wiring. I ran 2 12gauge wires to some 40 amp relays, tapped into the pink/black wire for my signal wire. Now at this point do most usually just remove the FPDM? I'm not sure what the other couple wires are for, I need to look at a diagram.
Next question, I still have the line that runs from my intake mani to the evap canister on my fuel tank. My concern pushing alot of boost into the tank. What do those of you that are pushing high boost do with this? I've left it as is for the last year @ 7-8psi, but plan on cranking it up.
I removed the stupid heated PCV that some bullitts came with. My PCV has been bypassed for awhile and the "T" in the heater core line is a known failure point.
Gotta plug this port on the intake mani
Threw on the timing cover, valve covers, and oil pan. Starting to look ready to install.
Also got a promotion tranny on order (750hp version) along with one of their clutches. Hopefully be here in a couple weeks.
Ok so when I got the MMR pan it didn't dawn on me that it comes with only a 3/8 bung for oil drain. My previous pan I had tapped with a -10 fitting and ran a -10 drain. Question is would I be ok running a -8 drain? I can't seem to find a 3/8 to -10 adapter and even if i used two adapters to make it, it seems kind of pointless to run a line that much bigger to bottleneck at the fitting. Thoughts?
Well I may end up removing the pan again and drilling the bung out to accommodate a -10 fitting. I used an -10 to 5/8 adapter with a crush washer and a nut on my last pan. Probably will end up doing the same with this one as I don't think I'll be able to weld on it without destroying the finish. Everything I've read suggests that I'll regret it if I just try to get away with the 3/8 fitting on the pan. Sucks it comes with one so small.
Dassar, what brand shorty headers are those, they look better made than others I've seen, are you happy with them so far?
I don't see any problem with using the bell housing bolts for lift points, keep in mind that the shear strength on those bolts is probably at least 10 times the engine/trans weight.
They are ford racing shortys. I actually bought them off corral a couple years ago. No issues with them. Of course i would like a forward facing kit, but its not in the budget right now.
Well got the motor and trans in. Just gotta tie up some loose ends and reinstall the exhaust/turbo stuff. Hope to have it started this week! Do you guys just make some kind of adapter to prime the engine prior to start?
Ok so I used a cheap HF transfer pump to prime through the bottom of the oil filter adapter. With that MMR pan It took nearly 9 quarts to get the level right. (which is good because I only have 9 quarts of break in oil) My tuner told me since I have the same MAF and injectors that I used with my last tune on the old motor that it should be fine to fire up/ light driving. Well she started kinda. Wont stay alive. After the first stall, it wouldn't restart. I pulled a plug and it was covered in fuel. So I guess I'm done for now until I can get a tune, which will probably take awhile.... unfortunately.
So I need some opinions. I'm contemplating ordering some weld rt-s wheels for a drag setup. What I can't decide on is what would look better with the DHG, the black or polished center. Opinions? I already have some black on my hood so that may help the black wheels jive. But I like the way the polished look too, thoughts?
I was looking at the black weld RTS setup and they do look great on dark colored cars but I havent seen the polished setup done right yet. You will definitely be unique because I've only seen the black welds on sn95's.
Ok, just got back in town a week or two ago and finally got a decent tune in the car. Feels good at 15psi, but i'm wanting to add a little bit more so i got a meth kit on the way. There is one issue though, I keep melting DPFE sensors. At first the hoses were blowing off, now I clamped them on and its melting sensors. I'm assuming this is pointing to backpressure issues, and I am running a full exhaust, with a shitty on3 76mm turbo, but this is the same setup I had on the last motor and I didn't have these issues. (although it was less boost) Any of you guys pushing a moderate level of boost still running an EGR?
Related Threads
Modded Mustang Forums
6.3M posts
80.3K members
Since 2005
