2003 GT/ 4v Swap
AIT Sensor in GTs?
Do the 01-04 GTs have an Air Inlet Temp Sensor? If so were is it? Thanks
2003 GT 1999 4v swap Full Bolt ons |
RLY SRS
They are integrated into the MAFS on the 02's I know...
Its the outside gray wires on the MAF... |
48.47@ 12.58
on some of the 01's they are not... they would be in the stock air box closest to the drivers side.
2003 GT/ 4v Swap
Ok well I have an 03 and I am getting a code saying that the AITS is faulty.
48.47@ 12.58
so replace it.
![]() it is in one of those 2 places.
2001 GT
![]() iTrader: 1 reviews
air intake sensor on the 01 gt is on the air intake between the maf and tb.
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,443 RWHP/ 386 TQ |
2001 GT
passenger side
48.47@ 12.58
I know where the box is..
![]() I meant that the actually sensor is located closer to the drivers side of the motor even though it's on the passengers side inside the air box.
It's in the MAF, that's why the newer ones have 6 wires...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
2003 GT/ 4v Swap
Ok well if mine has it in the MAF and I am using a different MAF that doesnt have it in it is there any way to split the wires and run a sensor into the intake. I believe this could be the cause of some of my problems. Has anyone taken the MAF wires and split them to a sensor?
#11 | |
RLY SRS
The Mean Green
yup these guys are right, its in the MAF on 02-04
2003 GT/ 4v Swap
bump
Threads Similar to: AIT Sensor in GTs?
| air sensor | johnr2001 | 99-04 | 3 | January 15th, 2008 06:23 PM |
| What Can I Use To Get An O2 Sensor Out, Help! | tjames | V6 Mustangs | 18 | December 18th, 2007 05:02 PM |
| TPS sensor | WNTS 2RN | 99-04 | 3 | October 3rd, 2007 08:58 AM |
| where is my iat sensor? | fordmust02 | Audio/Video | 6 | July 6th, 2007 02:36 PM |
| MAP sensor | ROBBED666 | 2005 - 2010 | 0 | October 9th, 2006 03:12 PM |
