Which bolts do I take out to remove a caliper?
Old January 23rd, 2008, 12:28 PM   #1
crappy_head's Avatar
2001 GT
crappy_head is on a distinguished road
Send a message via MSN to crappy_head
the ones in red wont nudge for shit and the ones in blue rotate but the never come out. what am I doing wrong?
HP 401 TQ 380 | Vortech V-2 SQ Intercooled | 410 Gears |Accufab 75mm TB | UPR O/R X Pipe | Flowmaster 40s
Eibach Sportline Springs | Steeda U&L Rear Arms | Subframe Connectors | Steeda Sport Shifter
Old January 23rd, 2008, 12:56 PM   #2
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
spray the ones that dont move with liquid wrench and let it soak for about 10 min....it should break em loose.
Old January 23rd, 2008, 01:13 PM   #3
prodrifterx's Avatar
prodrifterx is on a distinguished road
Send a message via AIM to prodrifterx
easiest way= pb blaster(panther piss aka). let it soak. use a 1/2" or 3/8" breaker bar with a short socket. easier to pull than push a breaker bar too. the blue bolts need a wrench on the backside. you remove these to disassemble the caliper more so that you can replace the slides, metal plates, and easily replace pads and compress piston. if just doing pads and rotors you should be able to remove only the "red" non-budging bolts. good luck.
Old January 23rd, 2008, 01:43 PM   #4
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
be sure to use a craftsman(or any brand with free replacements) ratchet with a cheater bar.... I broke 2 1/2" drive ratchets before mine broke loose on my foxbody, and got brand new replacements for free... and i had soaked it in penetrating oil for a day before I started... some are just a bitch to get off!
Old January 23rd, 2008, 04:39 PM   #5
2001 GT
well the PB worked and now that i have the caliper off i can see where the brake line hooks up the thread its all f'ed up. should i get a new caliper or do they sell something like a thread fixer?
Old January 23rd, 2008, 04:45 PM   #6
im sure you could make that attempt to fix threads...however you're best bet being a brake line and the main connection...would be to replace the caliper. my 2cents.
Old January 23rd, 2008, 05:03 PM   #7
R3dFyre02's Avatar
R3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura about
most things you can get away with repairing threads on... But I would not mess with brakes. bad things tend to happen if something fails. I would just replace them.
Old January 23rd, 2008, 05:06 PM   #8
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
Whooo is very inportant I think you will agree? buy a caliper. and use the proper (line wrench) next time.
Old January 23rd, 2008, 05:08 PM   #9
2001 GT
ok thanks
Threads Similar to: Which bolts do I take out to remove a caliper?
caliper color? stang300a Visual 8 January 25th, 2008 01:58 PM
Caliper Seize ScreaminYellow05 V6 Mustangs 2 October 29th, 2007 05:43 PM
$3 caliper painting texas_mustang 2005 - 2010 33 October 8th, 2007 11:47 PM
Got my motor...How to remove bolts from tranny GTXRacing 5.0 Mustangs 17 April 3rd, 2007 06:19 PM
Caliper Color SlammedGT Visual 9 October 8th, 2006 12:37 AM
