Gonna Lower it
BUT with all the options out here which kit to go with is the question. What have you gone with and why?
And if I lower it will a 17x10 1/2 deep dish rub on the rear?
Jon and Michelle Sarabia ----------------------------- My Rottweiler is smarter than your honor student! |
2002 Chevrolet Impala
Maximum Motorsports builds some really good suspension.
As long as you don't drop your car to the ground your rims won't rub. |
Naa, not going getto with it! LOL
This will be my next step also, I think im going with h&r ss, MM c/c plates, and not sure if im doing S/S or not, its recommended with the super sports but I dont think its needed, I just want a lower look, dont really care about better launches. the super sports are the best stance IMO and most people opinions, but not great for the strip.
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
all depends on how low you go. i beleive you would be ok. 2" drop will push it, and come very close or rub when suspension travels. but it also has to do with tire size. youre best bet would to be runa 275 tire minimum...(youd be stretching the tire to its width limit).....id say 285/295/305 tires.
specs 275/40zr17 goodyear eagle f1 rim width range 9-11 optimum rim width 9.5 overall diameter 25.7" (stock is aprox 25.8") overall section width (the problem spot) is 10.8" on a 9.5" rim 285/40zr17 goodyear eagle f1 rim width range 9.5-11 optimum rim width 10 overall diameter 26.1 overall section width (the problem spot) is 11.3" on a 10" rim 315/35zr17 goodyear eagle f1 rim width range 10.5-12.5 optimum rim width 11 overall diameter 25.7 overall section width (the problem spot) is 12.3" on a 11" rim add .5" to section width if rim width is .5" larger than optimum. subtract .5" from section width if rim width is .5" smaller than optimum. add 1" to section width if rim width is 1" larger than optimum. for more info....i used tirerack.com just search a tire size is the easiest way and click on specs. if you scroll down far enough it shows all sizes offered by that compny in that style. for instance all goodyear eagle f1 tires. they suck imo....especilly on vettes, even though factory puts them on. |
Threads Similar to: Gonna Lower it
| Who's gonna have these first? | akatagyourit | The Clubhouse | 15 | May 5th, 2008 02:43 AM |
| Your not gonna believe this | dgt_mustang | V6 Mustangs | 13 | January 11th, 2008 06:12 PM |
| Im Gonna Be Da BOSS! | 97Cobra | The Clubhouse | 119 | September 1st, 2007 02:28 AM |
| gonna be a dad | Drgnracin72 | The Clubhouse | 46 | August 30th, 2007 10:48 PM |
| Well I was gonna get an 03' GT but now I'm getting an 02' | mustangmanic | 99-04 | 14 | June 27th, 2007 06:10 PM |
