Oil pressure gauge
Old January 26th, 2008, 05:26 PM   #1
RC02GT's Avatar
2006 Saleen s/c
RC02GT is on a distinguished road
Send a message via AIM to RC02GT
Oil pressure gauge
What causes the gauge to read no pressure at cold startups sometimes and when I rev it it goes up then drops back off until the engines warm. the sender? how could I fix it.
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune
Old January 26th, 2008, 08:42 PM   #2
RC02GT's Avatar
2006 Saleen s/c
No ideas?
Old January 26th, 2008, 08:43 PM   #3
HMUSN's Avatar
iTrader: 9 reviews
I would think the sending unit.
Old January 26th, 2008, 08:52 PM   #4
RC02GT's Avatar
2006 Saleen s/c
and to fix it?
Old January 26th, 2008, 09:08 PM   #5
mattstang's Avatar
mattstang will become famous soon enoughmattstang will become famous soon enough
Send a message via AIM to mattstang
get a new one?
FX4 Crew
Crew member #3
Old January 26th, 2008, 09:44 PM   #6
1965 Coupe
zers is on a distinguished road
don't drive it till it's warm, so the sender works? or not give a crap?
http://i17.photobucket.com/albums/b57/mustangclint/SIG-Zers.jpg
Old January 26th, 2008, 09:54 PM   #7
RC02GT's Avatar
2006 Saleen s/c
I donno what it looks like or where it is, I guess it works cuz when its warmed up it reads normal pressure.
Old January 26th, 2008, 11:35 PM   #8
03Gtmustang will become famous soon enough
iTrader: 7 reviews
that same thing happened to my ford truck it turned out to be the cluster just not responding to the signal. i had the shop replace the sender and such and it worked for a while but just came back. so they took the cluster out and found a lose connection.
Old January 26th, 2008, 11:37 PM   #9
RC02GT's Avatar
2006 Saleen s/c
Well it happened with my stock cluster and now i have roush cluster in and still does it. I dont no what the sender looks like or how to replace it.
Old January 26th, 2008, 11:38 PM   #10
RC02GT's Avatar
2006 Saleen s/c
and it only does it when its cold out on initial startup, when she's warm its fine.
Old January 26th, 2008, 11:42 PM   #11
willsurforbeer9 is on a distinguished road
then let it warm up, problem solved.
2003 V6 Automatic
Ebay CAI
Soon to be for sale.
WTB 2003 Cobra with 75000+miles OR
2003 GT w/<50000 miles
Old January 26th, 2008, 11:46 PM   #12
iTrader: 7 reviews
hey man i found this it might lead u to the sending unit
is a nice tech sheet on the guages.
Complete Guide to your ford car instruments! - STANGFAN.COM - Ford Mustang ranch for pictures, mustang videos & chat.
Old January 27th, 2008, 12:00 AM   #13
RC02GT's Avatar
2006 Saleen s/c
THanks man I appreciate it
Old January 27th, 2008, 12:12 AM   #14
iTrader: 7 reviews
no problem i hope it helps
Old January 27th, 2008, 12:13 AM   #15
RC02GT's Avatar
2006 Saleen s/c
Yea it will, ill look it back up and try out what it says to do when i get my car back, itll let me know if its the sender or not, thanks again man
Old January 27th, 2008, 03:34 AM   #16
2001 roush stage 2
roush 2001 is on a distinguished road
i had the same problem with my 01 and the dealer couldnt figure it out they changed the cluster and sending unit and it ended out being the wire in the circuit to the cluster that had a break in it they just undid the wire solder it together and it was done
Old March 22nd, 2009, 12:55 AM   #17
DblAughtGT's Avatar
DblAughtGT is on a distinguished road
I would imagine that you have corrected this by now. But I just wanted to let you know that i was having a similar problem with mine. I could crank mine in the morn, and have good pressure, then as soon as it warmed up, pressure would drop when it was at an idle. Then, after the car had been running for about an hour or so, it was good, idling or not. So, I replaced the sending unit and havent had any problems since. It is located right next to the oil filter, cant miss it.
Old March 22nd, 2009, 01:09 AM   #18
schwarzGT's Avatar
2003 GT
schwarzGT is on a distinguished road
Be careful, my car had no oil pressure upon a cold start and it ended up starving the valve train of oil which in turn made for some nasty noises...good thing I turned it off to prevent further damage. That was after the car sat for a week in sub 20 temperatures though.
StangSuspension.com Series II 2 inch lowering springs, MM Caster Camber Plates, MM Strut Tower Brace, Steeda Bumpsteer Kit, Steeda Clutch Pedal Improvement Kit, Fidanza Aluminum Flywheel, Centerforce Dual Friction Clutch
Threads Similar to: Oil pressure gauge
fuel pressure gauge dr.gonzo! 5.0 Mustangs 10 May 4th, 2010 05:12 PM
Fuel Pressure Gauge rondaw3g0410 2005 - 2010 9 December 2nd, 2007 07:55 PM
Oil Pressure Gauge Question Pastor J 2005 - 2010 6 September 6th, 2007 01:25 AM
electric fuel pressure gauge chozen1 2005 - 2010 9 August 23rd, 2007 03:41 PM
Problems With Oil Pressure Gauge... Need Help! chase 5.0 Mustangs 4 February 9th, 2007 07:25 PM
