Cam Questions
Old September 20th, 2006, 01:27 AM   #1
MnrlGry01gt is on a distinguished road
Cam Questions
Ok guys I have a few questions about cams... here I go...
First, what does it mean by stall. Like when you are looking at the description and requirements for different cams it says you must have like a 2500+ stall. What is that?
Second, Should I save myself some money and install them myself or take it somewhere. I am not a car expert, just an ordinary home mechanic with a little more than general knowledge about cars.
Third, What do you think the is the best stage for my car. I have a CAI, Full exhaust, Gears, Throttle Body and Plenum are almost here, and Pulleys. Any brand suggestions?
Thanks everyone. Sorry its so many questions.
Old September 20th, 2006, 11:47 AM   #2
superbeef1000's Avatar
cams, stall
stall = tourq converter setting
and you have an 01 gt you can not use use the stage 2 or 3 cams do to the the amount of lift the cams will provide evan witha stage 1 cam you may need to see if there will be any piston to valve contact
some one please correct this if i am mistaken
Old September 20th, 2006, 03:04 PM   #3
MikeyS281's Avatar
1999 Mustang GT
14.2 no mods, bald tires
MikeyS281 is on a distinguished road
You are correct about the piston to valve clearance, however the Stage 2 or 3 cams can work, you would need to buy different cam gears to adjust the timing and everything so that they will clear. I'm not sure where you can get them but if you call Comp cams they prolly have them, if not they will be able to point you in the right direction. Let me know how things go.
Once a Marine always a Marine!
Semper Fi Marines!
Old September 20th, 2006, 04:45 PM   #4
Drgnracin72's Avatar
yeah youcan use the stage 2 but i dont know about the 3s. just make sure that even if you do the 1s, to replace the valve springs. go with comps, they make the best ones out there for the cash right now. maikey is right about having to go with different cam gears.
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old September 21st, 2006, 02:57 AM   #5
What about the install?
Old September 21st, 2006, 03:17 AM   #6
DaveT is on a distinguished road
if you are comortable with cam timming go for it
a friend once told me, procrastination is like masturbation, they both feel good until you realize you just f**ked yourself
Old September 21st, 2006, 06:10 AM   #7
well its not an install for someone whos not really well with this stuff or doesnt know what they are doing.
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Threads Similar to: Cam Questions
Few Questions Bies08 V6 Mustangs 12 August 21st, 2007 10:33 PM
rim questions SilverGT04 99-04 26 August 17th, 2007 01:54 AM
*a few questions* mustang1072 V6 Mustangs 10 June 28th, 2007 11:59 PM
Questions about new car! Blown93Cobra 5.0 Mustangs 6 June 4th, 2007 03:45 PM
2 Questions mikethetigerrr V6 Mustangs 21 October 25th, 2006 09:23 AM
