Drag Strategy
a friend of mine told me the other day not to floor the gas pedal when i take off after the light....he says wait till i gain enough traction to where my tires are not spinning and then punch it....well how to i know when exactly to punch it...do ya'll use this strategy or do you just punch it when you see the 3rd yellow light?
2002 GT K&N CAI O/R X-Pipe Race Bullit Mufflers SCT Xcal2 w/Custom Tune By RWTD 4.10 Rear Nitto D/R's FR500 Rims 17x9 17x10.5
1999 Ford Mustang V6
if you are running street tires and have bad wheelspin that will help but if your not having wheelspin issues and/or running drag radials or slicks hammer time! i see you have sticky-icky tires, what are you running? how was your 60ft? any track vids?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
right now i'm running high 14's with what i got...i'm running nitto D/R and my tuner and gears are going in on moday. hopefully i'll break into the 13's with the gear upgrade.
With the d/r's if you doing a burnout good enough to bring some heat into them, nail it. On a prepped track, I doubt you're gonna have traction issues.
11.21@123 -150 shot
![]() iTrader: 1 reviews
On street tires you will want to avoid the water box. Do just a quick burn out to clean off the tires, too much and they will get greasy. Bring up your rpms to 2500 and slip the clutch as you are applying the gas. It is a delicate balance but I have some 2.0s short times on Gatorbacks. That is not all that fantastic, I know several guys that can consistently get 1.9s on Skaterbacks. It can be done but you really have to feel it.
For drag radials, drop the pressure down to around 20-25 psi. Do a good smoky burnout and move your launch rpms up until you are getting a little bit of spin. A little is good. The most important thing is to document what you have done and adjust accordingly. Once you find what works for you and your car, tweak it until you are comfortable with it. Have fun and be safe.
awsome! thanx for the advice!
so what is a good tire pressure for street tires?
i have Nitto extreme drags on my car too!! the best launch on them is to heat em up w/ a quick burn out and let the car launch at right around 4000 rpms/ even mabye 3800 and your car should hook up. Also look at your tire pressure in teh back, your gonna want it lower than it says. mine say 44 i put em around 36psi. good luck. if you drive it right you should hit high 13's.
Threads Similar to: Drag Strategy
| A Drag Car! | JONJON | 5.0 Mustangs | 42 | November 18th, 2007 07:33 PM |
| Drag | sniperrider | 5.0 Mustangs | 3 | July 3rd, 2007 08:17 PM |
| 5.0 drag car | BsGms3 | 5.0 Mustangs | 39 | March 3rd, 2007 09:56 AM |
| about the SCT Strategy | V6boi | Audio/Video | 0 | February 21st, 2007 11:56 PM |
| anyone here play strategy games?!?!?!? | MSO | The Clubhouse | 20 | January 3rd, 2007 02:01 PM |
