Spark Plug Change... Piece Of CAKE!@!@! - Page 2
Old February 18th, 2008, 01:57 AM   #21
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
Originally Posted by DanTheMan View Post
I thought the cel was supposed to be on when you turned the key on (light test)
You are correct, it does turn on as a light test...but does not actually do anything with the actual built in test (BIT) of the car.
Old February 18th, 2008, 02:28 PM   #22
TyCouey2000GT is an unknown quantity at this point
I'm going to replace the wires first... It's just one of the wires that are hanging across the piping... I aint worried about doing the wires, I can do that,
Your Average GT
Old February 18th, 2008, 02:37 PM   #23
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Originally Posted by dude496 View Post
...aluminum strips so damn easy!
I have stripped three in the past few weeks. I've never had any problem and then all the sudden I can't keep em' from gaulding.
Old February 18th, 2008, 02:41 PM   #24
We finger tightened the plugs, then we torqued em... the anti seize helped them go in MUCH smoother...
Your Average GT
Old February 18th, 2008, 02:45 PM   #25
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Mine have probably been in and out about 50-60 times on this pair of heads. So, I'm sure the threads were just fatigued.
Old February 18th, 2008, 02:49 PM   #26
Proud American
MustangMatt96GT's Avatar
so ac how you going to fix that?
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old February 18th, 2008, 03:01 PM   #27
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Already fixxed. It's not that bad. I found some long inserts (not helicoils) and threaded the holes all the way from top to bottom. They are probably twice as strong as the origional threads.
Old February 18th, 2008, 03:11 PM   #28
Proud American
nice. Boomer makes all the threads longer on the all the heads he does.
No do you know if having longer threads means you can put the spark plug to far down in the cylinder?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old February 18th, 2008, 03:17 PM   #29
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Ummmm, yeah. I'm pretty anal about checking measurements. Anyway, I would suggest to anyone putting on a set of heads to go ahead and take care of the problem before it starts.
Old February 18th, 2008, 03:24 PM   #30
Proud American
how do you keep it from not been to far into the head? Do u just count the number of times you turn it?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old February 18th, 2008, 03:29 PM   #31
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I just use a straight edge and a depth gauge to set the insert at the right depth. I place the insert onto the spark plug and use the plug to place the insert into the newly tapped threads. Next, I use the top of the plug for reference as to how far the insert needs to be seated. Having already coated the insert with loctite, I just leave everything alone until the next morning or evening and then pull the plug out and flare the top of the insert in order to properly seat the locks.
Old February 18th, 2008, 03:32 PM   #32
Proud American
I was actually asking about the actual spark plugs in the heads. Like can you put the plugs to far in the cylinder that you may smash the tip or anything.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old February 18th, 2008, 03:36 PM   #33
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I guess you could, but you would have to fuck something else up in the first place. That's why it's important to make sure the inserts are locked into place before you screw in the plugs and start running the motor again.
Old February 18th, 2008, 03:43 PM   #34
Proud American
oh, i dont have experience with thread inserts or helicoils, I didnt know u needed to put a lock. But now i understand how it works kinda. It was just something I thought of.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Threads Similar to: Spark Plug Change... Piece Of CAKE!@!@!
Spark Plug Change 00redgt 99-04 55 January 5th, 2009 12:33 PM
Spark plug gap??? flamed 98 gt 5.0 Mustangs 9 January 14th, 2008 10:37 PM
Oil with my spark plug!! HELP caintcatchmyGT 96-98 24 November 1st, 2007 12:22 AM
spark plug gap white93pony 5.0 Mustangs 8 October 13th, 2007 10:51 AM
spark plug gap droppedbass87 96-98 6 June 4th, 2007 10:40 PM
