99 GT SOHC to DOHC
Old September 27th, 2006, 11:34 AM   #1
MikeyS281's Avatar
1999 Mustang GT
14.2 no mods, bald tires
MikeyS281 is on a distinguished road
99 GT SOHC to DOHC
I was thinking of going with the DOHC heads for my GT, if I do this will have to get a Cobra computer or anything? What are the different things that I would have to get in order for this type of mod to work right?
Once a Marine always a Marine!
Semper Fi Marines!
Old September 27th, 2006, 11:39 AM   #2
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
You need to splice in the 4 Valve maf and 4 Valve injectors into the harness you have now...
Then you need to have a chip burned for your GT computer with a 4 Valve tune on it...
Then from what I have heard/seen that is it...
I think you could use the 99-01 Cobra stuff...Maybe the Mach 1 Stuff (dont see why you couldn't)...I am not sure if you can use the parts from an 03/04 Cobra but you should be able to...
Hope this helps...
Facebook
Google+
Old September 27th, 2006, 12:17 PM   #3
Drgnracin72's Avatar
you will also have to have your block drilled and tapped, becasue the timing components on the 4v motor are different from the 2v motor. it will be more cost effective to buy a cobra motor. but you can amke a shit ton more power with the 4v. but then again if you dont plan on making more than 500 hp i wouldnt do it
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old September 28th, 2006, 01:44 PM   #4
MikeyS281's Avatar
1999 Mustang GT
Thanks man, I will go with a DSS short block for a Cobra and 4v heads.
Semper Fi Marines!
Old September 28th, 2006, 01:44 PM   #5
MikeyS281's Avatar
1999 Mustang GT
Hope this helps...
Thanks for the help man I appreciate it
Semper Fi Marines!
Threads Similar to: 99 GT SOHC to DOHC
sohc to dohc usmc513 96-98 3 October 30th, 2007 05:59 PM
sohc to a dohc? gtdan 96-98 11 September 6th, 2007 02:53 AM
SOHC to DOHC energiesource 99-04 9 May 16th, 2007 11:06 AM
SOHC to DOHC NMR-2vGT 96-98 6 March 13th, 2007 11:51 AM
SOHC 4.6 to DOHC 4.6 rattlesnake28977 Modular Mustangs 8 December 6th, 2006 03:16 AM
