Took the Mach to the track yesterday just to see where it sits before I drop it off at the shop in 2 weeks. I know the autos are a lot slower than the sticks and from what I've read they run 13.8-13.9 @ ~102mph stock. It was slick and drag radial night so the track prep was top notch. I think I made the mistake of putting a dr on a stock auto Mach because it did not help me at all and my times didn't even come close to what it "should" run. Car is very stock with the only mods being welded in Flowmasters and Steeda sport lowering springs. The car sat on 17x9 front Mach black wheels with 255/45/17 rubber and 15x8 Weld Prostars with 275/50/15 BFG drag radials with 19psi.
Out of 3 runs fastest 60' and 1/4 pass was:
60': 2.150
330': 6.154
1/8: 9.323
MPH: 78.81
1000': 12.011
1/4: 14.296
MPH: 98.73
It just couldn't get off the line quick enough and didn't have top end pull. The 2.15 60ft came from brake torquing to 1100 rpm and then hammering it. The car did not spin or bog on any of the passes. I was expecting a 13.6-13.8 out of it because of the drag radials, but it was a dog off the line. Basically running in stock GT territory.
So comparing this to my blown GT, at ~3,475lbs it is already 40lbs heavier than my GT with longtubes, intercooled centri blower setup, Cobra front brakes, full length frame connectors, and driveshaft safety loop. If I could've somehow got it to do a 1.90 60' it might have ran a 13.80.
This was the first time for me going down the track in an auto. Boy is it boring! lol Didn't know what to do with myself for the next 12 seconds after the car got moving.
I'm hoping that in a month it will be a completely different animal. Circle D 4c 3800 stall torque converter, BCA modified valve body, VRS o/r x pipe, and intercooled Vortech V1 S at ~11psi should wake this thing up.
60': 2.150
330': 6.154
1/8: 9.323
MPH: 78.81
1000': 12.011
1/4: 14.296
MPH: 98.73
