So I have some weird **** going on with my electrical system. First my dash lights have stopped working, when I put my headlights on dim my abs light and right turn signal light come on. I can turn my fog lights off and they go off. When I remove the key from the ignition. My fog lights stay on and the odometer stays on until I push my fog light switch. I had tapped into the blue and white wire on my headlight switch for my gauge lighting and thought that was the problem. I removed the gauge light wires and still have the same issue. I also thought the blue and white wire was for the dimmer but my new gauges will not dim when I turn the knob. Any ideas?
---------- Post added at 02:53 AM ---------- Previous post was at 02:32 AM ----------
I have checked all of the grounds and they are all on good shape.
I had a very similar issue two years ago. I had a bad ground on the passenger side. There is a ground up on the top of the radiator support that was loose and it created all the same problems you've described. I'm betting it's a ground issue.
Might be nothing but hey any suggestion might help here. Is the ground to the engine still good? I've heard if it's severed it can cause some weird gremlins.
Thanks for all of the input. I am going to go over all of my grounds again. And if that doesn't help I am going to relocate the battery back on the engine bay. This issue is the only thing keeping me from finishing my build so really want to get it resolved.
Weird issue solved! It was a ground issue. I had removed the ground on the passengers side of the radiator support at some point and it had gotten kinda tucked behind the headlight. Reconnected it and problem solved. I do still have the issue of no instrument cluster lights. I checked fuse #13 and it is good. Any suggestions?
I had an issue when i tapped into my dimmer for gauge power. Worked fine for bit, but Now my instrument panel lights and gauges lights only work when my dimmer is turned to the max power. a hair below max and none of the light work. been that way for a while now just have to always have my dimmer set to max.
I tapped into my blue and white wire for my gauge lights. My gauges light up but don't dim. My instrument cluster doesn't light up at all but all the gauges work. Just no Illumination.
Issue resolved! Apparently with all of the gauge installs,removal and more installs I left the #37 Illumination fuse out. Now I feel like a total dumbass. I have a bad habit of looking at the worst case scenario first. Anyway with that resolved I will be installing my wideband tonight and then ready for a tune! Still gotta get aa electric fuel pressure gauge. Just Santa Claus sees this post... Lol
Related Threads
Modded Mustang Forums
6.3M posts
80.3K members
Since 2005
