31 spline spider gears
will 31 spline gears fit in 28 spline unit,I dont want to pull bearings and re shim unit ..
RLY SRS
The gears are the same...
The differential and axles are what are different the gears are the same... |
yea I have 31 spline axles.I wanting to install 31 spline spiders to install axles.just wanting to know if they will fit in unit....
RLY SRS
The gears are swappable...But for 31 spline axles you need a 31 spline diff...
Do you already have a 31 spline diff? Or are you trying to make a 28 Spline Diff into a 31 Spline Diff? As far as i know you cant do that... |
#5 | |
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
#6 | |
RLY SRS
Never heard of anyone doing it... So I really dont know how to really answer this... |
I have both units 31 and 28..28 inthe car now ..im wanting to put 31 spline in, to use alloy axles ,I will take it apart and find out ..I will post if it fits
#8 | |
Other than being courious which I'm too. I guess it make it easier to reshim since you could put it back together the same way it came out. I have the usa alloy axles and I'm very happy with them.
would be sweet if you only needed 31 spline spiders
2000 GT, 5spd, K&N drop in, king cobra kit, full dyno tune, pypes o/r x and violator, MGW, termi front clip http://www.youtube.com/mrgearhead87 |
I dont want to pull unit out of car..if i install 31 unit i have to reshim it and pull the bearings..Im trying a quick fix...
I will post this weekend...im thinking the housings are the same
no will not work ,31 unit is bigger...so I will have to reset the gears
Threads Similar to: 31 spline spider gears
| zippys spider is the crack spider | mpboy | The Clubhouse | 9 | October 5th, 2007 04:00 AM |
| unidentified spider | DanishStallion | The Clubhouse | 25 | September 10th, 2007 08:45 PM |
| Spider man..? | El_Cangri | The Clubhouse | 14 | July 10th, 2007 11:01 PM |
| Spider X9 Hood | marcfiebka | 99-04 | 1 | April 21st, 2007 02:49 AM |
