Just by googling it and knowing what I know about Fords (take this with a grain of salt) I personally would swap o2 sensors and see if the fault code follows it. I'd follow it up with cleaning the maf and pulling the plug on cylinder 1 to ensure it isn't cracked, broken, or gummed up. If it is, I'd replace all plugs for good measure. Same with o2s. Reset computer and see what happens.
I always start with the basics. I've replaced o2s that were faulty, spark plugs that were gummed up, and cleaned dirty maf (even had to replace one due to k&n and over oiling). I found a lot of issues I had with my Explorer on the minor things like this can happen with the mustang. Sounds like you got a good days worth of trouble shooting and such. Good luck!
the problem is the stupid misfire comes and goes, i checked 3 plugs today before it got dark they didnt look too bad, cops looked ok. i swapped the cyl 1 cop to the other side. its still misfiring but the service light hasnt come back so i can see if it moved to the other side with the cop. ill probably end up replacing the plugs this week
Related Threads
Modded Mustang Forums
6.3M posts
80.3K members
Since 2005
