Cobra brake upgrade - Forums at Modded Mustangs
 4Likes
post #1 of 50 Old January 5th, 2017, 01:56 PM Thread Starter
Cobra brake upgrade
Don't know if anyone has posted these before, but I found this on eBay. Looks like a cheap way to do the cobra upgrade. What do you guys think?
http://m.ebay.com/itm/Front-Red-Brak...ATCHING_ACTIVE
foxcobra262 is offline
post #2 of 50 Old January 5th, 2017, 02:41 PM
Nile P. Pezdel of Pez Dispenser Inc. CCA
nileppezdel77!'s Avatar
Maybe, but if I'm being honest, I do not trust random eBay listings with no manufacturing information for brakes or tires or mostly anything really.
'01 GT Convertible
Maximum Motorsports TQA|PHB|FLSFC|LCA|Coilovers
D&D T56 Magnum; Cobra R Brakes; Sparco Seats
Tuned by Mustang Magic and so much other stuff
'16 Fiesta ST
Cobb FMIC, RMM, Air Filter
Tuned by Stratified
nileppezdel77! is offline
post #3 of 50 Old January 5th, 2017, 02:54 PM
Cletus Emmett Wheelwelker
MG2V's Avatar
Those aren't Cobra calipers. They are GT/V6 calipers.
46L281GT and Hailscott like this.
MG2V is online now
post #4 of 50 Old January 5th, 2017, 03:15 PM Thread Starter
I emailed them, they're 13" rotors so I would assume the calipers match. I could be wrong, but I think the pre terminator cobras had the 38mm caliper which I think are stock gt size pistons and the 03-04 had the 40s. I mainly want to do it because the guy before me put 13" rear brakes on my car and it looks kinda stupid with the 11s up front.
post #5 of 50 Old January 5th, 2017, 03:40 PM
Nah, I promise you. You ain't getting twin piston Bullitt/Mach/Cobra calipers with that price. 38mm= before 98 and 40mm=99+
2003 GT
MM Torque Arm |MM Panhard bar | MM Coilovers | Koni Yellows | Cobra Brakes F&R | Brake ducts F&R | MM C/C plates | MM XL SFCs | MM Adj. LCA | Much More |
03FR500 is online now
post #6 of 50 Old January 5th, 2017, 03:47 PM
MG2V's Avatar
94-98 Cobra front calipers had dual 38mm pistons. 99-04 Cobra/Bullitt/Mach 1 calipers had dual 40mm pistons. 99-04 GT/V6 calipers had dual 44.5mm pistons.
Seems strange the seller is telling you they come with 13" rotors, because the calipers in the first photo in the listing are definitely not Cobra calipers. I would specifically ask the seller if the kit includes Cobra calipers, and not GT/V6 ones.
MG2V is online now
post #7 of 50 Old January 5th, 2017, 03:51 PM Thread Starter
I would definitely make sure it's the right stuff before buying. It does say the picture is a representation and may not match completely.
post #8 of 50 Old January 5th, 2017, 03:57 PM Thread Starter
Their actual website, not the eBay store, has different part numbers for cobra non cobra stuff. I'm going to email them more and find out.
post #9 of 50 Old January 5th, 2017, 04:23 PM Thread Starter
They emailed me back, they said the calipers are the cobra models. I'm just going to order them and be the test mule. If they're what they say they are it's a super deal, if they're not I'll just return them.
post #10 of 50 Old January 5th, 2017, 05:14 PM
MG2V's Avatar
It's a great price if it works out for you.
MG2V is online now
post #11 of 50 Old January 5th, 2017, 05:38 PM Thread Starter
I just ordered them so I guess we will find out. Once they're here I'll takes som pics and do a little review on them.
nileppezdel77! likes this.
post #12 of 50 Old January 5th, 2017, 11:45 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
You have to also send back your core calipers...
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
11.50@121.77@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #13 of 50 Old January 6th, 2017, 06:45 AM
US Air Force (retired)
Eagle2000GT's Avatar
I've always wondered about that. Will they give back the core charge for GT calipers? They do not advertise that the calipers fit a GT.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Also own: 1997 Harley FXDWG, 1998 F-150, and 2002 Corvette LS1
Eagle2000GT is online now
post #14 of 50 Old January 6th, 2017, 08:46 AM
46L281GT's Avatar
wouldn't you potentially need different brake lines with the correct banjo bolt? Just a thought.
1999 Mustang GT 5 Speed Vert
Procharger P1SC @ 7 lbs
382/382 STD
Tuned by Chicken Hawk Motorsports
Supercharger Build Thread: http://www.moddedmustangs.com/forums...ld-thread.html
46L281GT is offline
post #15 of 50 Old January 6th, 2017, 09:31 AM Thread Starter
I think the stock lines will work but I'm not 100% on that. As far as the core, even if they don't take them I think 250 is still a hell of a deal. If they do and they fit no way you could beat 180 for a 13" brake upgrade. Like I said though, we'll see. For all I know they won't be right, but I should know probably tomorrow or Monday.
post #16 of 50 Old January 6th, 2017, 10:47 AM
Stock lines will bolt up, I put 03 Mach1 brakes on my V6 and the stock lines bolted in fine when I tested it. I ended up going with stainless lines in front since I was already there and figured do it all at once, but either option will work.
2003 Redfire & Black V6. Full suspension, 8.8 w/ 4.10s, tuned. 4.3L built for turbo + turbo capable of 550 hp on the way
DD: 2015 SHO PP, CAI, Axlebacks, Tune,blacked out/AMR wheels. 12.87 @107 1/4 mile (1.8 60')
Derfdog15 is online now
post #17 of 50 Old January 6th, 2017, 01:12 PM
46L281GT's Avatar
I also upgraded to stainless steel lines when i did the upgrade so i wasn't sure about the old lines.
382/382 STD
46L281GT is offline
post #18 of 50 Old January 7th, 2017, 03:14 PM Thread Starter
Well, had an issue. The rotors and pads showed up without the calipers. I called them and they'll be shipping out on Monday. Not that big of a deal as the car is sitting anyway. So I guess I will see what happ be when they show up Tuesday.
post #19 of 50 Old January 7th, 2017, 03:42 PM
MG2V's Avatar
Are the rotors 13"?
MG2V is online now
post #20 of 50 Old January 7th, 2017, 03:59 PM Thread Starter
Yes, they're 13". Look like good quality parts, good maching on the drill and slots. No defects that I see.
Human Verification
