Setting up gears... marking compound? - Forums at Modded Mustangs
post #1 of 9 Old January 9th, 2017, 10:54 AM Thread Starter
BumbleBee
iTrader: 7 reviews
Hey all, I'm trying to set up the gears in my 8.8 and I will admit this is the first time I've ever set up gears. It's been a long road but I have a pretty good handle on it now. The problem I'm having is I can't for the life of me see my damn gear pattern. I look online and I see all these nice yellow paint marks with distinct patterns shown.
I bought 2 kinds of compound, one yellow, one white/yellow and I still get nothing. My gears just seem to wipe the entire tooth clean. Some parts look like it's completely wiped and then others look like the gear wiped it slightly but was lifting. It's hard to tell where exactly my pattern is sitting and I don't think it should be wiping the entire tooth clean. Could I really have gotten it dead nuts on perfect by accident? Something just doesn't seem right. Am I supposed to let the compound dry for a while on the gear before spinning it?
69MUSTANGCOUPE393CID is offline
post #2 of 9 Old January 9th, 2017, 02:10 PM
GBPackerFan's Avatar
We used the compound provided in the gear kit.
We applied it on the Ring gear. I don't think we let it sit too long. I used the Ford guide to compare patterns and ours was dead on the first time we checked. We did measure backlash first and obviously pinion pre-load. We re-used my pinion shim as well from the 3.27 set (I put in 4.10s).
Yours looks like it is contacting well on both gears. I'm no expert by any means so hopefully someone else chimes in for you. How does it compare to the Ford Guide Gear Pattern? If you need me to, I can find a link to that install guide I used...let me know.
My gears have absolutely no whine at all. Been going for about 10-15k miles now and down the drag strip several times.
Matthew 26:52-54 / Go Pack Go!
2001 GT Convertible - Cammed / Geared / Dyno Tuned 263rwh/290rwt
1994 V6 Convetible - Stock
2009 Malibu LTZ - Stock
GBPackerFan is offline
post #3 of 9 Old January 9th, 2017, 03:13 PM Thread Starter
BumbleBee
iTrader: 7 reviews
Pinion preload is close; not set 100%, but close. I was just getting a test run done before I went crazy in case the pinion shim had to be changed. Backlash is currently at about .008, it was at .012 first shot, but I didn't want it that loose with new gears especially, so tightened it up. I still want to get it closer to .010 but I can't for the life of me tell if the pattern is good or not. It sure as hell looks like it's wiping the whole gear and that the pattern is deep enough, but I can't tell where the ring gear is lifting off the pinion. I want to be sure it's not going off the edge of the gear tooth.
I see all these patterns online and it just looks like everyone has this nice distinct pattern exactly where the gear is wiping. Mine it seems like it just wipes the compound completely off the ring gear. I want to say I have a perfect pattern but this isn't something I want to guess at, I'd like to get a pattern I can better read.
post #4 of 9 Old January 9th, 2017, 04:28 PM
I would say let the compound dry for a bit. It will be more distinct the more dry it is.
post #5 of 9 Old January 9th, 2017, 06:01 PM
lenko's Avatar
slather the compound on 4 or 5 teeth really well on the ring gear. If it's too dry some suggest to mix a few drops of gear oil and mix it in the compound. What your pattern (what you can see of it) suggests pretty good contact, but it would be nice if it were more definitive.
http://www.moddedmustangs.com/forums...1&d=1483999225
lenko is offline
post #6 of 9 Old January 10th, 2017, 12:04 AM
I got no advice, I'm getting ready to do my first R&P intall in a few weeks. Please post back on what and why the issue was and the solution.
Best of luck.
Infinite Monkeys is offline
post #7 of 9 Old January 13th, 2017, 01:03 PM
a.k.a. Racecougar
Tang Stang's Avatar
Are you providing some resistance to the ring gear with your hand while turning the pinion?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Tang Stang is offline
post #8 of 9 Old January 14th, 2017, 10:37 PM
Not sure what youre doing wrong,bt ive done hundredds and cant say ive ever had that happen
Pm me for billet T45/3650/T56 forks. Usually in stock.
Bottledgt is offline
post #9 of 9 Old January 18th, 2017, 02:40 PM Thread Starter
BumbleBee
iTrader: 7 reviews
Yup.
I ordered some new marking compound so I'll find out this weekend. The last set of gears I had done (had help from a mechanic but he let me watch) used the little bag that came with my gear set and the patterns showed up great. I ordered that little bag from motive in hopes it works well.
Human Verification
