Hey all, I'm finally starting to get my engine together and was reading over the ARP instructions and saw that the main studs will cause a .07" difference in my oil pickup location. I guess because of the washer that will be under the nut for the main stud. That being said how have you guys corrected this?
I do have a windage tray going in which will probably push my oil pan about .035" further down and I suppose if I use another factory gasket between it, I will probably get back to the correct pickup to pan clearance. But if I decided to not use a second oil pan gasket and just use RTV how would I correct for this?
TIA
TIA
