https://youtu.be/omhHK7_XCIs
You can really hear it around the 16 second mark and forward. Basically its like a humming or whining noise. It's not the car speakers as I had it turned off. Almost sounds like its coming from the rear passenger side but I can't tell. Sounds louder on decel, but can't tell if that's because of the exhaust or what.
Does it sound transmission related or wheel bearing related? Rear end related? Can't tell. It still makes the noise when the clutch is pushed in. The sound completely goes away when the car is still or in neutral. Starts about 30MPH and gets worse from there. Thoughts?
---------- Post added at 02:09 PM ---------- Previous post was at 01:44 PM ----------
From what I read could be gears whining, but it's completely stock from the factory. Can factory gears fail? Need ideas where to look. This is completely new to me.
FYI Car is a 5-speed with 95K miles
