Engine Stalling Problems!
Old October 12th, 2006, 02:08 PM   #1
crewdog318 is on a distinguished road
Send a message via AIM to crewdog318 Send a message via Yahoo to crewdog318
I have a 2001 GT with a 4.6L. It has 68,000 miles on it & has developed a start up problem.
When I start it up for the first time of the day, or it sits for a few hours, the engine starts but RPM goes right to zero. I can keep it running by giving it some gas to maintain the RPM's but have to left foot the brake when stopping. This condition lasts sometimes 20 -25 miles then everything returns to normal.
BTW....until it returns to normal, the RPM's are higher and the transmission has different shift points.
I've cleaned the K&N filter, changed the plugs & checked every vacuum line. ANY IDEAS? HELLLLLLLLLLLLP!
Old October 12th, 2006, 02:44 PM   #2
Drgnracin72's Avatar
iac valve, could also be a problem with the tune!
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old October 12th, 2006, 02:45 PM   #3
im trying to find the thing about how to clean it.
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old October 12th, 2006, 08:18 PM   #4
Engine stalling
IAC valve? What does IAC stand for?
Old October 13th, 2006, 12:04 AM   #5
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
idle air control. You can remove it and clean it with brake parts cleaner. That should clean a lot of carbon out of it, but sometimes the valve can be bad enough that you have to replace it. I'd try the barke parts cleaner first and see if that fixes it.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old October 13th, 2006, 01:48 AM   #6
energiesource's Avatar
energiesource is on a distinguished road
yeah i had a problem
i cleaned it but it didnt do shit
i'll be driving and all of a sudden slow down and it'll go down to like 300 rpm, ill pretty much lose power steering, everything, so yeah. then it goes back to normal after i give it gas
Old October 13th, 2006, 02:29 AM   #7
The valve might be sticking. I would replace it.
2001 Bullitt #5069
Old October 13th, 2006, 06:41 AM   #8
Engine stalling
Thanks for the info. I'll replace the IAC valve & see what happens. Thanks again.
Old October 13th, 2006, 04:54 PM   #9
Engine stalling
Guess what? The IAC valve fixed my pony!! We're back in business!
Many thanks to DRGNRACIN72!!!!!
Old October 13th, 2006, 04:58 PM   #10
how mucgh did you pay for yours?
Old October 13th, 2006, 05:11 PM   #11
engine stalling
$52 at Autozone. I didn't want to go thru the hassle of cleaning it & wondering how long it would last.
Old October 13th, 2006, 05:16 PM   #12
omfg mine is 182 everywhere i call
Old October 13th, 2006, 05:38 PM   #13
MidniteGT is on a distinguished road
Just a question what is the IAC Valve made of and where is it at. Just a question. And also Crewdog, are you in the USAF?
True clue crew member #8 -- F15E CC
Old October 13th, 2006, 07:16 PM   #14
engine stalling
MidniteGT..........I'm retired from the Air Force now but was a crew chief on F-111's, F-101's, F-4's and finished on the Falcons. Never had the pleasure to crew an Eagle.
It's a metal cylinder shaped object located on the leading edge of the throttle body. It has 2 bolts & one connector. It takes me longer to change my oil than it did to change the IAC valve!
Threads Similar to: Engine Stalling Problems!
Engine Problems? James 99-04 14 March 2nd, 2011 01:20 AM
Help! (Engine Problems) 97ponylover Modular Mustangs 13 February 9th, 2009 10:13 PM
engine problems? B.A.M302 5.0 Mustangs 5 September 4th, 2007 11:49 PM
engine problems? B.A.M302 5.0 Mustangs 7 June 5th, 2007 12:27 PM
Explorer stalling problems Kevin General Tech 4 February 3rd, 2006 05:02 PM
