Clutch squeak
Old April 3rd, 2008, 07:33 PM   #1
Rebel Of The Sacred Heart
travis_afx's Avatar
'02 GT
travis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of light
Clutch squeak
Anyone got a suggestion as to why when i let my clutch pedal out, in the last inch or so i hear a squeak. Is the cable rubbing the liner or something. Also when the car is running the squeak is louder if that means anything?
Or maybe its my TO bearing?
I think it is going out becuase occasionly when she has been sitting for a while like over night, there is a constant squeking sound(totaly different squeak here) that goes away as sooon as i start to push the pedal in, but it always goes away after about five or so miles of driving , then it will comeback at a later date.
Travis Billings
May 6, 1982 - July 5, 2011
Rest In Peace brother, you will be missed.
Old April 3rd, 2008, 10:45 PM   #2
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
sounds to me like early signs of a bearing going...when that squeaking noise turns into a grinding noise, you will know for sure its a bearing going out.
Old April 3rd, 2008, 11:17 PM   #3
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
yep... i was there 2 weeks ago. my throwout bearing was grindin SOOO BADD!!
Old April 3rd, 2008, 11:20 PM   #4
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
and it will eventually look like this:
ask me how i know
Old April 4th, 2008, 12:20 AM   #5
travis_afx's Avatar
'02 GT
Ouch!
So its not that difficult to change right?
Travis Billings
Old April 4th, 2008, 12:22 AM   #6
travis_afx's Avatar
'02 GT
Are you talking about the squeak that happens when i let the pedal out? Because it actually seems like i can kinda "feel" it grinding a little through the pedal.
Travis Billings
Old April 4th, 2008, 12:23 AM   #7
13.00 @ 105
you have to pull your trans far enough out to reach up in there and pull the old TOB off of the clutch fork and put the new one in
Old April 4th, 2008, 12:26 AM   #8
travis_afx's Avatar
'02 GT
does it just slide off or is there a fastener of some kind holding it in the fork?
Travis Billings
Old April 4th, 2008, 12:37 AM   #9
13.00 @ 105
there is a clip that holds it on... not hard to get off though
Old April 4th, 2008, 01:30 AM   #10
travis_afx's Avatar
'02 GT
cool, thanks shocker
Travis Billings
Old April 4th, 2008, 01:46 AM   #11
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
also little bit of advice here. the TOB need to be relubed even if it has its own lube. DO the reuse the old lube trick.
if your tob is going you may want to consider doing the clutch also if you never replaced it before...
Mods in garage. Built suspension and gears since posted times.
Threads Similar to: Clutch squeak
Squeak Noise Monster90 99-04 5 December 21st, 2007 06:55 PM
Windows Squeak? Reset 99-04 11 August 6th, 2007 10:02 PM
squeak mustang1072 V6 Mustangs 5 February 21st, 2007 10:34 PM
squeak stang638 V6 Mustangs 31 February 11th, 2007 03:33 AM
Squeak Squeak! DC97Cobra General Tech 4 November 26th, 2005 11:13 AM
