#21 |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
#22 | |
MM's Mad Scientist
Slow Fella
It's pretty simple. I'll scan the diagrams I have and post them in this thread later today.
Thanks for the compliments. I won't have it tuned until Monday.
#23 | |
2001 Mustang GT
tuned by SPEEDY DYNO 12.41 @ 109 mph w/ CMS stage II cams 11.13 @ 122 mph NX 150 shot ![]() Launch soft, shift slow, rev low, stay slow
#24 |
MM's Mad Scientist
Slow Fella
I am currently running 2 07 GT pumps. Both the pumps are internal. I modified my basket to accept the two returnless pumps, and installed a -8AN bulkhead fitting in the hat to deliver the fuel from the second pump. Currently, I have two seperate line run all the way to the fuel rails. However, I am planning on swapping the two lines out for 1 -10AN line when I get a second Aviator pump. I should have mentioned that the two GT pumps are temporary. I already had them, so I stuck them in. They should be good for ~ 700 RWHP. However, I would like to run two Aviator pumps just for extra insurance. Give me just a minute and I'll scan the wiring diagram in.
#25 |
MM's Mad Scientist
Slow Fella
Here is the modified diagram. There is really no reaon to run two relays. Just get a good relay and 10ga. wiring from the battery.
![]() This sheet comes in really helpful, because the diagram is listed in wiring colors and the new pigtail for the FPDM will come with all black wiring.
#26 |
2001 Mustang GT
Very nice, thanks for the info
#27 |
MM's Mad Scientist
Slow Fella
When I get another pump and all my line/fittings, I will try to remember to take plenty of pictures and do a write up. It's pretty simple. Trying to keep the wiring straight is probably the hardest part.
#28 |
2001 Mustang GT
Thanks again. I may go with something like this when I convert to a plate kit. I was thinking about just adding a BAP since my power level isn't anywhere near yours.
#29 | |
MM's Mad Scientist
Slow Fella
Your power level can be whatever- just spray more N2O......... That's my theory anyway.
#30 | |
2001 Mustang GT
#31 |
MM's Mad Scientist
Slow Fella
I smoked my factory block with 150 shot a whie back. It will give you the kick in the ass to build a new block though.
#32 | |
2001 Mustang GT
#33 |
MM's Mad Scientist
Slow Fella
You must have some money. I would imagine you have a little dough invested in suspension.
#34 | |
2001 Mustang GT
#35 |
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 13 reviews
AC if i remember correctly isnt the nozzle for the dry kits supposed to go before your MAF sensor? Why is your installed after?
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
#36 |
MM's Mad Scientist
Slow Fella
I'm not using the MAF to add fuel and take timing. That will be done with the tune. It would be to much for the MAF to compensate on a big shot (200+).
#37 |
2003 Mustang GT
12.28 @ 116
Ah I see. I had no idea you were running that large of a shot.
#38 |
MM's Mad Scientist
Slow Fella
Well, I totally fucked up. We started tuning on the car with the dry shot last night. It picked up about 100 HP on an 85 jet to start with. Next, it made right at 500/600 on a 145HP jet. Everything is great, so we throw in a 175 and it picks up 5 HP---- You read that right- 5HP!! Anyway, we go ahead and throw in a 205 HP jet and lose 2 HP. I was like "WTF??". Anyway, as I'm pulling the jet out to check everything, I notice just how small the inside of the output line from the solenoid is. By measurement, it should have only made about 140-150HP. I didn't think anything about the -3AN line being too small at the time I was installing it (DUH!!), but oh well. I have another -3AN line and another fogger nozzle on the way. I am going to come off the solenoid with a -4AN fitting and branch it into two -3AN line and twin dry nozzles. Maybe this will finally get this thing to swallow a 250 shot.
IT's always something. However, I did get a killer deal on a NOS 10# bottle and a cheater solenoid last night ($40 total), so it wasn't a complete loss. Oh, and BTW, the car is so much smoother on the dry shot- it is unreal, and my duty cycle on the pumps is only running about 62% on the 145 shot. Plus, those 60# injectors look great.
Threads Similar to: Dry kit, window switch, & extra FPDM installed pics
| Window Switch | mystang0673 | General Tech | 3 | November 19th, 2007 05:58 PM |
| window switch? | 00redgt | 99-04 | 6 | November 5th, 2007 06:03 PM |
| rpm window switch. | mustangrebuilder | Audio/Video | 0 | September 18th, 2007 08:58 PM |
| window switch | barksdaleammo | General Tech | 31 | May 23rd, 2007 09:33 PM |
