Discussing Focus SVT Pump... in the 99-04 Forum. I think i just read that the Focus SVT pump comes from the dealership. True? ...
Old April 8th, 2008, 12:35 AM   #1
Focus SVT Pump...
I think i just read that the Focus SVT pump comes from the dealership. True? Working at a body shop, we get a GREAT discount from dealerships. I was told to get this pump seeing that im supercharging my 00 GT with a p1sc and intercooler w sct 2600 maf and 42lb inj. and a tune. This pump will be enough wont it???
Old April 8th, 2008, 12:41 AM   #2
mbmconstruction00's Avatar
2004 GT
yeah...thats what im running...it will support as much or more power than ur stock block will be able to handle
Vortech Mongoose Kit,Meth Inj,Mac LT's & Pro-Chamber,SLP LM2,3:73,Accufab T-Body & Plenum,Pro 5.0 Shifter,FR500 Deep Dish Rims,H&R Springs,KYB Adj,MM CC Plates,Mach 1 Grill Delete & Spoiler,HID's,Saleen Wing,Steeda X2 & Bumpsteer
Old April 8th, 2008, 12:48 AM   #3
what kinda hp you got? i am looking to get 390-420 or so.
Old April 8th, 2008, 12:57 AM   #4
2004 GT
hasnt been dynoed as of yet...im waiting to get a front mount and an anderson power pipe before she gets tuned...right now i just have a canned tune from modular powerhouse....but that pump will be fine at 420....ive seen cars with slightly upwards of 450 with that pump
Old April 8th, 2008, 01:00 AM   #5
why do some peeps have problems when at top speeds. Ive read a couple stories of motors blowing while running the car at top end and i think some said it was because the motor wasnt getting enough fuel. this is what i was wondering about. how much was that canned tune you got?
Old April 8th, 2008, 01:25 AM   #6
supercharged03gt's Avatar
2003, Mustang, GT
I am running that pump and dont get enough fuel at the top end. you can feel when it starts to go lean. I just let off at that point. its at about the 5000 mark in 4th gear. I am buying a kenne bell boost a pump in hopes it will fix the problem.
Mods: Vortech V-1 supercharger, BBK LT headers, BBK o/r X pipe, Flomaster cat back, 4:10 gears, Centerforce clutch, Fidneza aluminum flywheel, K-member, Eibach pro kit, MM caster camber plates, Eagle F1 tires 275 & 315.
Old April 8th, 2008, 02:24 AM   #7
1999 Mustang GT
Agreed. This pump is not good enough at top end. I have my boost a pump set at 40% to make the pump not peg anymore.
Old April 8th, 2008, 02:28 AM   #8
1999 Mustang GT
Maybe on some cars but my pump was pegged at 390hp.
Old April 8th, 2008, 02:47 AM   #9
2004 GT
yeah its weird...numbers are all over the place...ill have to keep an eye on my wideband while winding out fourth...ive never heard of them going lean up there n ive never taken notice
Old April 8th, 2008, 02:56 AM   #10
2003, Mustang, GT
How do you know how much % to run on the boost pump. cant you just run it all the way or could that hurt the pump?
Old April 8th, 2008, 03:12 AM   #11
1999 Mustang GT
I used my xcal to datalog and you can tell when the fuel pump pegs. My fuel pump gets up to about 92% when I set the bap at 40%.
Old April 8th, 2008, 03:13 AM   #12
1999 Mustang GT
Mine pegged when I did a run from 2000 rpms to redline in 3rd.
Old April 8th, 2008, 07:21 AM   #13
2001 GT
I run my BAP wide open all the time never had no issues.
2001 Gt,auto,J mod, 4:10s, B&M cooler, Hitech stage 2's, NX plate 100 shot, 75 mm tb, C&L upper plenum,BBK X with magnaflow's,Black FR 500,S,SCT tune from Bama chips.
Old April 8th, 2008, 09:59 AM   #14
instead of the boost a pump, is there just another fuel pump that would be better so that a boost a pump wasnt needed?
Old April 8th, 2008, 10:02 AM   #15
MM's nicest mod, :)
White99stang's Avatar
you should not run a blower car up to top end anyways dude unless its tuned for it. Your car is tuned for the load it makes in 4th gear, so when in fifth gear there is more load so in a top speed run its going to go lean because of the load on the motor. If you get the car tuned they will have to add more fuel and drop timing if they know that your going to try to drive 145+
Have a Nice Day, Especially MSO
99 Mustang GT VT 302 Stroker 11.13@123 f.s. 9k
06 Dodge MegaCab Diesel 455rwhp/815rwtq
Old April 8th, 2008, 12:43 PM   #16
Authorized Vendor
Trick Tuners's Avatar
KB'd GT
I've seen focus pumps peg at just over 400hp WITH a bap. The cobra (termi) tank and pumps is the best way to go for mild setups. Every time i have a customer with a focus i tell them it will peg and they say, "so and so on the internet hit XX hp with one" But then it always pegs and they have to add a bap, or new pumps. The focus pumps only flow slightly more than the stock pumps. Might as well add the GT (supercar) pump. They flow way more and cost less.
Note that this graph is TWIN focus pumps.
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX wideband products @ Trick Tuners
email joe@tricktuners.com
PM for super MM member deals!
Super Cheap Motorsports Camera to record the Action!
Old April 8th, 2008, 01:49 PM   #17
limited's Avatar
a single gt pump flows slightly less than the stock twin cobra pumps,I would put in the single gt pump
99 limited edition conv. KB 2.1 9 psi intercooled.vt stage 3 blower cams,gt40 fp/bap,vt covers,frpp 3:73's,demolet cai,accufab 75mm tb,Sct Ba 2400,tri-ax,bfg kdw's,magnaflows
Tuned by Joe at http://www.tricktuners.com
Old April 8th, 2008, 03:04 PM   #18
I run a P1SC...9 lbs of boost, 3 row intercooler and the Focus pump. I also drilled a few holes at the base of the plastic basket that houses the fuel pump. I dynoed out a 386 HP and have never had a fuel lean problem at high RPMs after my tune. We also set it a little on the rich side for added protection. I have experienced a miled lean condition when the fuel level is low at high RPMs. Thus the reason I drilled the holes in the basket.
The difference between a girlfriend and wife is about 50 pounds.
Old April 8th, 2008, 03:38 PM   #19
Hell i need to know which one to get. im ready to get this damn thing going. ha. Which pump? Ford GT?
Old April 8th, 2008, 03:54 PM   #20
What about Aviator?? and what is this talk about drilling holes?
Threads Similar to: Focus SVT Pump...
SVT Focus Fuel Pump Uncle Humjaba Air/Fuel 24 October 24th, 2008 02:34 PM
Getting A Focus Fuel Pump Uncle Humjaba 96-98 19 January 1st, 2008 10:23 PM
Focus SVT Fuel Pump install gsjohnson 99-04 5 September 16th, 2007 03:40 AM
SVT Focus vs 04 GT TheBusher Street 21 August 1st, 2007 08:23 PM
svt focus pump vs. ford GT pump undomesticfire 99-04 3 May 15th, 2007 08:10 PM
