![]() ![]() ![]() ![]() iTrader: 13 reviews
Changing Shark Plugs
where are the spark plugs on our cars? anyone got a picture they can upload and show me where they are?
thanks.
Under the coils, very easy to install too...
2003 Sonic Blue Mustang GT Steeda cold air intake Bassani off-road x-pipe Magnapacks Steeda Tri-Ax Shifter |
here:
the coil packs are right next to every injector... they look like black cylinders... the plugs lie right under them
#5 | |
Thanks, for uploading that.
yeah that helps. i didnt know if it was the Big black tops or the Pink tops. Now i know. Thanks.
the pink thing is your fuel injector, its like a 7mm to get the top screws out if i remember, and use 5/8 spark plug socket with swivel head and extension. use a little antisieze and dont overtighten, dont mess with your fuel rail, its not in the way.
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
yeah make sure u use the spark plug socket if not u will have to fish the plug out
Never Ran er!
you might have to remove your fuel rail on the passenger side, when you put it back together make sure there is an o-ring on every injector, the person that was helping me do one side while I was doing the other didn't realize the o-ring fell off and when I turned my car on gas poured everywhere.
nah, just did mine last week, and the fuel rail diddnt get moved at all.
Yeah I have never had to take off the fuel injector. Just the intake tube, easy job expecially compared to ohv engines. Don't get me started on an LS1 or even the explorer 5.0
2002 gt vert
what are some good spark plugs to use on the 2v motors
2002 mustang gt vert. 18' bullitts k&n drop in air filter flowmaster mufflers soon to have mac off road x pipe and steeda udp pullies |
copper plugs ngk
2002 gt vert
so part number?lol
i'm using the motorcraft platinum plugs they seem to be workin pretty good for me.. well then again i'm still using the motorcraft synthetic blend as well.. soo.. newayz.. if u dont have any good fancy swivel tools and all, u might have to take that damn fuel rail off.. i took both of mine off, cleaned up the injectors while i had them out too.. i even had to take my TB off jus to get to those 'easy' to reach spark plugs.. lol.. oh well atleast i got them done and over with now
"For I have made mistakes, which made me a better man, I will forever believe that you can live with NoRegretz" '95 5.0L Vert www.wotmustang.com MILITARY CREW
E-5 |
i used auto lite copper tops
wow guys now im confused haha. OK fuel rail? Is that the Chrome Bar that is holding everything down?
Also under that Chrome Bar there is a big black cap there are 4 of those on each side. next to the Black caps there are then Pink little tops with Wires going into them. Why are there wires going into the Pink Top. Aren't those the Spark Plug? I know wires connect to the spark plug but ive never seen them that way before.
yes.. that would be the fuel rail. those would be your fuel injectors your talking about not your plugs.
wires don't connect to your plugs. you have coil packs meaning that you don't have spark plug wires.
Ok so if the pink top are my Injectors then where are the plugs??
Threads Similar to: Changing Shark Plugs
| Changing The Plugs | JASonic | V6 Mustangs | 31 | April 8th, 2008 03:42 PM |
| Was Changing Plugs And... | 1979rs/z28 | 99-04 | 9 | December 19th, 2007 01:38 AM |
| Changing Tranny Fluid??? Where are the plugs??? | Slowbra_12 | 96-98 | 3 | August 6th, 2007 11:24 PM |
| Just got a 2000 GT, advice on changing Plugs and Springs | Philipk2003 | 99-04 | 6 | June 25th, 2007 11:56 PM |
| need an easy way of changing my plugs in my 2000 (v-6) | timwade | V6 Mustangs | 1 | February 25th, 2007 06:01 PM |
