Discussing oil pressure and water temp gauge install question in the 99-04 Forum. Is it okay to leave the stock oil pressure sender off when installing an autometer ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1999 Mustang GT
Is it okay to leave the stock oil pressure sender off when installing an autometer one? What about the stock water temp sender? I'm guessing yes on the oil and no on the water?
Vortech V2-SQ
#2 | |
N/A 4v Guru
2003 Mach 1
No the stock ones send signals to the ECU and with them off it will throw a code for bad oil pressure or bad oil pressure sender.
![]() Gone To Basic Training |
1999 Mustang GT
And what does that effect?
Vortech V2-SQ
N/A 4v Guru
2003 Mach 1
Limp mode and a check engine light on all the time.
1999 Mustang GT
So I have to somehow hook up 2 pressure senders and the oil pressure feed line all in that tiny space?
Vortech V2-SQ
1999 Mustang GT
What is limp mode?
Vortech V2-SQ
N/A 4v Guru
2003 Mach 1
As long as the ECU gets the signal it needs. You can use the autometer one and tie the ecu signal wire in probably or use the stock one and tie the autometer wire in. For the coolant temp one are you going off the stock location or the screw in plug on the the drivers side of the block?
1999 Mustang GT
Is it safe to drive to the hardware store since I only put the Autometer one on?
Vortech V2-SQ
#9 | |
1999 Mustang GT
Vortech V2-SQ
#10 | |
N/A 4v Guru
2003 Mach 1
Yea. It should take a few driving cycles before it starts giving you trouble.
1999 Mustang GT
How do I know the sensors dont put out different signals and the computer might think the pressure is really high or something?
Vortech V2-SQ
N/A 4v Guru
2003 Mach 1
It's on the drivers side of the block, you will have to get under the car. Its a 16mm screw in plug, it will be just under the bottom freeze plug. Do you have an adapter in you gauge package? If not you will have to get one to use the plug.
#13 | |
N/A 4v Guru
2003 Mach 1
Is there not another plug in the oil filter housing to put the autometer one in?
1999 Mustang GT
I can't see any.
Vortech V2-SQ
1999 Mustang GT
I just put everything where the stock sensor was coming out of the filter
Vortech V2-SQ
#16 | |
N/A 4v Guru
2003 Mach 1
What does the instructions say to do with it?
1999 Mustang GT
"Install sender into pressure port of appropriate type."
Vortech V2-SQ
N/A 4v Guru
2003 Mach 1
LOL thats specific.LOL
1999 Mustang GT
The temperature one is even better "Install temperature sender." Thats the entire instructions for it.
Vortech V2-SQ
N/A 4v Guru
2003 Mach 1
Is the water temp one electric?
Threads Similar to: oil pressure and water temp gauge install question
| Water Temp Gauge | gotboost562 | 5.0 Mustangs | 2 | January 31st, 2008 12:16 AM |
| Aftermarket Oil/Water Gauge Install | GTPONY1 | 2005+ | 4 | January 19th, 2008 04:33 PM |
| Fuel Pressure Gauge Install | 01dutchGT | 99-04 | 8 | January 13th, 2008 09:58 PM |
| Oil Pressure Gauge Question | Pastor J | 2005+ | 6 | September 6th, 2007 01:25 AM |
| Water Temp & Oil Pressure | gotboost562 | 5.0 Mustangs | 1 | September 4th, 2007 11:50 PM |
