Discussing Torque in the 99-04 Forum. What mods are needed to get the maximum amount of hp to the ground? How ...
Old April 14th, 2008, 01:32 AM   #1
Torque
What mods are needed to get the maximum amount of hp to the ground? How do you increase torque on a car?
Old April 14th, 2008, 01:34 AM   #2
the real shocker's Avatar
13.00 @ 105
suspension is where its at dude....
control arms, subframe connectors, adjustable shocks/struts are a great start...
coil over set-up with drag springs, tubular parts to help weight transfer
Old April 14th, 2008, 01:42 AM   #3
What control arms would you recomend?
Old April 14th, 2008, 10:21 AM   #4
13.00 @ 105
maximum motorsports will get the largest vote around here... but i have UPR's and LOVE them.... both are adjustable
Old April 14th, 2008, 12:17 PM   #5
MATT02GT's Avatar
I love my Steeda control arms
Old April 14th, 2008, 02:09 PM   #6
I vote upr as well...Adjustability is the best option...all cars and drivers are different...
Old April 14th, 2008, 02:57 PM   #7
MM's Mad Scientist
2003 GT
Street Fast 16.9@76MPH
TQ is derived from cylinder pressure. You can get cylinder pressure by making your combustion area smaller, forcing more air into the cylinders (supercharger, turbo, heads, cams, etc.), or by making your combustion more volatile (increased timing, nitrous).
Old April 14th, 2008, 02:59 PM   #8
mustangmanic's Avatar
13.334 @ 106.27
AC... how safe is it to increase timing with stock heads and a stock cam? I would like to squeez a little extre hp outta my car before i go FI.
Accufab 75mm TB and Pleunm, JLT cai, Steeda Caster Chamber Plates, Eibach Sportline Springs, Tokico Shocks/Struts, Steeda Tri-Ax, FRPP Aluminum Driveshaft, FRPP 3.73's, Hooker LT's, Hooker O/R X, Pypes Violator Catback, SCT Xcal 2. 280rwhp 302.1rwtq
Old April 14th, 2008, 03:02 PM   #9
MM's Mad Scientist
2003 GT
Generally speaking, timing can be raised without issue from stock parameters. You have to remember that your car has a very soft tune from the factory to avoid excessive warranty claims and due to varied fuel supply from customer to customer.
Old April 14th, 2008, 06:12 PM   #10
And with a head and cam setup, how much can timing be adjusted?
Old April 14th, 2008, 06:13 PM   #11
MM's Mad Scientist
2003 GT
That depends on alot of variables.......
Threads Similar to: Torque
Low End Torque supermachone V6 Mustangs 26 February 11th, 2008 07:41 PM
Torque Ensit Mike 2005+ 7 April 16th, 2007 08:56 PM
Torque??? jonnotch 5.0 Mustangs 4 April 2nd, 2007 11:47 PM
torque...? geofarrey V6 Mustangs 10 February 8th, 2007 05:54 PM
Torque Stan27 General Tech 8 April 30th, 2006 02:00 AM
