2010 Mustang GT
13ish
Water Pump
Within the last week I was reading a thread where somebody had mentioned a water pump swap that will actually help you more than getting ud pulleys. I can't find the post to save my life so I'm just gonna ask about it. Also, what is the difference between a 00 tranny and an 02?
2010 GT Black (as if there's any other color) 340hp 320tq Black Mustang Club Member #2.0
2010 Mustang GT
13ish
where can i get this? i wonder if it has less bearing friction or if its just better flow?
#4 | |
N/A 4v Guru
2003 Mach 1
Better blade design, better blade material. It only draws 3hp at 6k rpm. You can get it thru summit.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
2010 Mustang GT
13ish
awesome, but what about the tranny question. i know my t5 sucks balls and a 6 speed is in the "need to do" list but whats the difference in the 00 and late 01 02 tranny's? a lot of times they upgrade but it really isn't
N/A 4v Guru
2003 Mach 1
You have the t-45 and they have the 3650. The 3650 will hold a little more power in stock form and it has internal shift stops. I would say go with a built t-45. Direct replacement for your car and it will hold more than a stock t-56. 56 swaps get pretty damn pricey
N/A 4v Guru
2003 Mach 1
Here is a link to the pump. When ordering make sure you get the one for long water pump 4.6
EMP/Stewart Components STE50046L - EMP Stewart Ford Mustang 4.6L High Performance Water Pumps - summitracing.com
2010 Mustang GT
13ish
nice, i was thinking about a built 5 speed, another gear would be nice though. i've got a tri-ax so shift stops really isn't a problem and i've been driving a while so i don't push the shifter past engagement. thanks for the info
do u have to pay for shipping with summit?
http://www.cardomain.com/ride/3112249 |
cool i get a discount there...what kind of hp's do the OE pumps use?
N/A 4v Guru
2003 Mach 1
Well the electric water pumps give you about15-17 at the wheels and use no hp to run. So do the math. If it takes 3hp for the Stewart pump then you will get about 12-14rwhp. I noticed a very nice gain with mine, especialy on the top end. Sweet2k has it and so does Machboy, they both saw similar gains
![]() iTrader: 3 reviews
I just ordered that water pump and a steeda pullies I will be installing it Sat. will let you know how the gains are.
12.73@111.36
I've been running a Meizere electric water pump for about 15,000 miles. I did a lot of things at once, but the tuner estimated a 15 rwhp gain.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
so $ to hp the one from summit is well worth it! Thanks!
Threads Similar to: Water Pump
| water pump? | 02gtbangstang | 99-04 | 0 | January 12th, 2008 12:53 AM |
| Water Pump | Badasstang281 | 99-04 | 2 | December 27th, 2007 05:40 PM |
| Water pump | 90Stang | 5.0 Mustangs | 13 | July 8th, 2007 04:57 PM |
| what water pump | 95wip | 5.0 Mustangs | 2 | June 25th, 2007 12:04 AM |
| Water Pump | cobralini | V6 Mustangs | 1 | August 3rd, 2006 06:48 PM |
