Fuel System Setup????
Old April 17th, 2008, 08:02 AM   #1
evildaweasel's Avatar
2003 Mustang GT
7.90@93 1/8 on street tires
evildaweasel is on a distinguished road
My fuel system is at its limits, so . . . leathal performance now has a system that stays returnless, uses dual pumps and fpdms, or should i go aeromotive returnless?? i kinda leaning toward returnless , because there will be 600hp coming before too long.
Thoughts??
Old April 17th, 2008, 09:23 AM   #2
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
dude i doubt you need to get a all new fuel system with your setup. Just buy a 03 cobra pump assembly and put dual ford gt pumps in them or svt focus pumps in them and there ya go. 600hp is not that hard to do fuel system wise at all.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old April 17th, 2008, 09:28 AM   #3
2003 Mustang GT
what will need to be done if i just put the cobra hat in with the pumps? or is it just a stright forward drop in?
Old April 17th, 2008, 10:11 AM   #4
2003 Mustang GT
what about this?? Fore Precision Works 03-04 Cobra Billet Top Hat [LP-TOPHATMOD] - $419.99
Old April 17th, 2008, 10:28 AM   #5
Trick Tuners's Avatar
KB'd GT
Yes, but the cobra tank has a baffle and the gt tank does not. You should keep it above about a 1/3 tank if you go with the cobra pumps in a GT tank. Dual GT pumps in a cobra hat and tank setup with dual fpdms is the way to go.
Old April 17th, 2008, 11:34 AM   #6
2003 Mustang GT
awsome thanks
2003 GT - stg2 p1sc, 42lbers, 255 pump, 373 gear, c&l plenum, 75mm tb, o/r x, Flow c/b, ebaich front, 4 cyl rear springs & 50/50s, u/l arms, others. SOLD
2010 GT jlt intake, comp mutha thumprs, prochamber, and flowmasters.
Threads Similar to: Fuel System Setup????
Complete fuel setup? chaosstangman 5.0 Mustangs 6 February 15th, 2008 02:40 AM
carb fuel setup chaosstangman 5.0 Mustangs 0 January 16th, 2008 05:14 PM
Exhaust system setup 06GT300 2005 - 2010 1 November 12th, 2007 05:39 PM
Full V6 Exhaust System Setup v6smoker V6 Mustangs 8 October 27th, 2006 10:12 AM
wich fuel injectors with this setup?... frankenstein 5.0 Mustangs 1 June 18th, 2006 11:34 PM
