Help Diagnose Steering Wheel Shake PLS!
I've got an 02 GT Automatic, 77k mi, with a pretty significant shake in the steering wheel from 50-80mph.
Here's a list of what I've checked and/or ruled out:
I think tie rods, etc are OK. Jacked it up and pried up and down and side to side on each front wheel. Didn't detect any looseness, etc. Any ideas? This is very annoying. TIA. |
It's a Mustang, not a mercedes. Don't expect it to ride llke one.
![]() Mineral Gray Club Member #2 Just your average 22 year old dumbass If you didn't build your car, and your bragging about it, STFU |
48.47@ 12.58
hmm I'd toss on some 4 bols C/C's for the hell of it. it may help your problem.
welcome to the forums.. did you get a printout of the alignment so you could cross check?
take it to a diff shop and have them look at it. i took mine to 3 diff ones before one realized i had a bent tie rod end.
FX4 Crew
Crew member #3 |
2001 Mustang GT
UNKown
![]() iTrader: 1 reviews
Nor is his car a yugo and should not drive like one .
radjxf -if you can try putting different wheels up front (ask somone to lend you theres if you can) -check the ware on the tires . -try another shop just to be safe. keep us posted
Mods: -PyPES cat back -Ford racing springs -Tires 275/17x9F & 285/18x10R -S&B Cold air intake -R498 10" Fixed Black mist Antenna ![]() ©1969-2010 |
13.00 @ 105
bad ball joints?
The Mean Green
Sounds like tire balance, tie rods/balljoints or bearings. With the front end in the air wiggle the tire from side to side, if theres excessive movement...tie rods. Wiggle the tire from top to bottom, if theres excessive movement...wheel bearings.
I.D.G.A.F.
It could be as simple as dirt on the backside of a wheel. To tires that have worn funny.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
2000 Mustang Gt
It seriously sounds like a balancing problem..... I had the same problem before. I took it to a different shop to have the balance rechecked, and it was way out of balance. Fixed the problem.
![]() Tuned by Joe at Tricktuners.com |
1998 Camaro SS
Does the car pull one way or another when you let go of the wheel, that could help pin point maybe more of a certain side of the car.
rotate your tires front to back (if you dont have DRs or staggered wheels) see if it helps but yes its in the tire, wheel, or a balance issue
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
2003 Mustang GT Vert
X2 - If you've had the wheel/tire combo balanced twice, I would go with one of the others suggestions...
aligment soundds like ur prob,but a bearing could also be bad.my work car has a bad ball joint an it doesnt shake ,how bad is the vibrating
02 ROUSH STAGE 2
Does this happen while driving or when brakng at those speeds?
Threads Similar to: Help Diagnose Steering Wheel Shake PLS!
| steering wheel | ThE GhOsT RiDer | 5.0 Mustangs | 0 | March 25th, 2008 05:10 PM |
| '06 GT Steering Wheel R&R- Help | Goldenpony | 2005 - 2010 | 16 | February 2nd, 2008 01:29 PM |
| Steering Wheel | Baker02125 | Visual | 20 | December 24th, 2007 03:06 AM |
| Wheel shake | MustangMatt | 2005 - 2010 | 9 | October 6th, 2007 10:17 AM |
| Steering Wheel Shake | rockerlynne | 2005 - 2010 | 16 | March 1st, 2007 07:45 PM |
