LinkBack (10) | Thread Tools |
#21
2003 MUSTANG GT
11.86 @ 114.21
thats actually not to bad
#22 |
2001 Mustang GT
UNKown
![]() iTrader: 1 reviews
good job BOB
Mods: -PyPES cat back -Ford racing springs -Tires 275/17x9F & 285/18x10R -S&B Cold air intake -R498 10" Fixed Black mist Antenna ![]() ©1969-2010 |
#23 |
Good write up.
A hydraulic trans jack can be rented fairly cheaply and would have made reinstalling the transmission much easier. Also it helps to have the trans in gear and turn the output shaft to get the splines to engage. |
#24 |
Boost gets you laid
update:
the spec clutch was GARBAGE. i had to pull it out re-do everything. i got a fidanza 2.1 and put it in and it is awesome. a couple things i think are important to add after doing it again: when you tighten the pressure plate down, torque all the bolts twice, in a criss cross pattern and don't tighten them all down all the way the first time around. also, when you clean the pressure plate, clutch disc, and flywheel, clean them before you put them in and also as you're about to mount them because grease from your hands can get on them when you're moving them around under your car. use break cleaner, i was told that if you use acetone it may not take all the cosmalene off the parts
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
#25 |
Boost gets you laid
i realized i had a trans jack yesterday when i was doing the project. as i was laying under my car i looked under the work bench and there it was, just sitting there never used. lol i felt like an idiot. i used it this time and it made it a little easier. still a pain though.
#26 |
Boost gets you laid
another edit: my pressure plate bolts came loose after about 500 miles. make sure you use a lot of loc-tite on your pressure plate bolts.
#27 |
I am in the middle of doing this right now, let me tell you its a project! BUT i found some little things that help,
the splining tool is great, but it kinda sucks that its plastic, i put it in, and pushed up on it a little bit and it made things easier, i had a snag where the tranny and engine weren't o the same angle so i pushed on the Alternater, (lightly!!!!) and i could hear everything fall into place. Sorry this isnt in order, im going off memory and its 7am on a sunday... But jacking, i used car ramps on the front wheels, but the concrete floor im working on wouldnt allow me to drive up them, jack up the car, place a jack stand, jack up the other side put in a car ramp, and go back to the first side jack and install second ramp. Its easy and it give a nice stable platform to work with. In the rear i jacked it up about 19 inches, put some heavy duty stands, and as a safety stacked wood, 10 x 10s up to the chassis jack point, i dont entrust my life to jack stands if i can help it. The starter removal was a nightmare, it took 3 of us taking turns to fine the right angles to get the bolts out, i wouldnt normally admit this, BUT i want other people to learn from our mishaps and plan accordingly! The other nightmare was the pilot bearing, this cost us a LONG time. It wouldnt come out, even using the bearing remover, (the tool with the prongs at one end, screw the handle and the prongs come out, and use the slide to hammer it out) eventually my friend, used a torch and heated it lightly, when that didnt work he used a pnuematic cutter of some sort, when i find out what its called i will edit this post, burred out the sides a little bit and out she came, he was careful not to burrow through into the crankshaft! I can say this, without a torch and an airgun this project would have laste more than 3 days. Things nice and rusted, the airgun helped out a lot. As i think of anything else ill through it in here, good or bad so i can try and be as helpful as i can. Meanwhile, I thank Bob, you can bet i printed off his directions and they are being used as a guide, im swapping transmissions ( 5 speed for a 5 speed), Aluminum FW, Spec Stage 1 Clutch and Steeda Adjustable cable kit. Bob, your write up is amazing, and +Rep for you!!!!!!
"I do not have to tell you who won the war. You know, the artillery did." ~Gen Patton K&N CAI, Spec Stage 1 Clutch, Spec Alum Flywheel, Steeda Clutch Adjust Kit, Eibach Pro Kit, 275s front, 315s rear, Insane Driver with Adrenaline Junkie Adapter |
#28 |
2001 Mustang GT
so you dont have to drain the tranny fluid? I heard that you got too but from this video i guess not huh
#29 | |
13.00 @ 105
#30 |
2011 Mustang GT
12.1 @ 116
+1
Mods in garage. Built suspension and gears since posted times. |
#31 |
i replaced mine a few months ago and i did it at a friends house since he had a lift, it took three people to get it out we had to push the headers apart just a little and then we could turn it so it came out. when we put it back in i had a transmission jack to help hold the load since it takes a few minutes to get it turned right but then it just slides in
#32 |
Is it hard to do when u got longtubes on? do u have to do anything to the headers?
![]() Zurdo |
#33 |
why was spec garbage? mine squeaks was your like that, i have about 400 miles on it. i also have an adjustable clutch cable firewall, and quadrant, all spec and aluminum flywheel. car shakes in 1st and reverse unless i give it alot of gas
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
#35 |
Great write up. I've never heard of replacing the pilot bearing while you're in there, just the throw out bearing. I have 21k miles on my Bullitt I don't think I need to replace it.
#36 |
Tree Fiddy Z
I wish the stupid faggots at the nissan dealership would have replaced the throwout bearing when they replaced my clutch because that's been the problem all along. Grrrrr I'm angry
#37 |
Great write up..one question. How long did it take you and did you have an extra pair of hands?
MM Cobra Club #20 1999 Cobra - Custom black/silver paint, 18" chrome Saleen wheels, BBK CAI, H-pipe, bullet mufflers, FRPP 4.10's and 305 Nitto DR's |
#38 |
Tree Fiddy Z
#39 |
It's a great write up, but could you make a list of all the tools used?
#40 |
April 18th, 2008, 06:28 PM <---- am i the only one that noticed this post is OLD AS HELL!! lol
![]() 480RWHP 450RWTQ 15psi @ 15* on 91 octane |
Threads Similar to: replacing your clutch? look no further.
| Replacing Clutch | bbrewer03 | 96-98 | 3 | August 4th, 2007 05:59 PM |
| Replacing amp, need help | mikebert | Audio/Video | 6 | June 17th, 2007 09:12 PM |
| Replacing OEM Clutch ABCs / Brake Upgrade | OcOnnor220 | 99-04 | 2 | April 14th, 2007 09:07 AM |
| Replacing a Clutch Without a Lift | OcOnnor220 | 99-04 | 4 | February 16th, 2007 12:09 AM |
| Replacing cannons.. | B0mb3r645 | 96-98 | 8 | August 1st, 2006 02:24 AM |
