October 20th, 2006, 12:17 AM
#1
I wonder how much it would cost..
To do this to the engine, or if its even possible.
Engine
The CCX is powered by a Koenigsegg designed and assembled, all aluminium, 4700 cm³ DOHC 32-valve V8 engine based on the Ford Modular architecture enhanced with twin Rotrex centrifugal superchargers with response system, 1.2 bar boost pressure and an 8.2:1 compression ratio. The engine produces 806 hp (601 kW) and 678 lbf.ft (920 Nm) on 91 octane (U.S. rating) gasoline, 850 hp (634 kW) on 98 octane (Euro rating, 95 octane US rating) gasoline and 900 hp (671 kW) on biofuel. The engine is lubricated via a dry sump with external oil pump, features oil spray piston cooling, and an external oil cooler.
