![]() iTrader: 1 reviews
Steering Wheel Problem
i took ppls advice and used the search function but found nothing about this
and im pretty sure this is a tech question so i dont see the harm in asking this today i was going about 50 on a slightly curvy road and when i started going towards the right where the road curves my wheel like locked up...so i when to the other lane and almost got hit head on. i ended up slamming my brake and pulling my ebrake and spinning through the grass on the left side of the road i have no clue wtf happed when i was stopped i couldnt turn the wheel at all so i shut the car off and when i turned it back on everythign was normal again anybody know wats wrong...im a little worried to drive rite aboug now, i mean if this happens again i might not be so lucky
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
Air could have built up in the line, causing a lock. Same thing can happen with the brake and the gas.
Just fyi, slamming on the brake and ripping the e-brake are 2 of the worst things you can do. When your in the situation though, you just do the first thing that pops into your head, haha. |
2000 Mustang Gt
hmmm, that's a new one. There steering shouldn't lock, even if you car stalled as long as the key is still on it doesn't lock. So I don't seem to be much help. Glad you're OK.
![]() Tuned by Joe at Tricktuners.com |
well i wasnt touching the brakes at all on the turn and barley on the gas cuz i was in 4th
how do i make sure this doesnt happen again
this has happened once b4 but it was rite after my antilock brake line got ripped off so i thought maybe that was why
becuase it happened wh slamming my brakes on
2001 Mustang GT
UNKown
Same thing happen to my friend (on a chevy) and same thing happen to one of our Ford partol Vans .it was the ignition switch that had gone bad on the chevy and on the van it was the key that was very worn out .
sorta like when you turn to lock the wheel when the key is not in the ignition. Any ways if your having problems with your ignition, like attempting to start the car but the key wont turn. then look at your key very good to see if its worn and try a better key or it might be ignition switch itself that might need to be replaced. if both your keys are worn go to the ford dealer show them your registration and drivers licence and they can cut you a new freash key for your car. anyways best of luck glad your safe and hope we can help you out.
Mods: -PyPES cat back -Ford racing springs -Tires 275/17x9F & 285/18x10R -S&B Cold air intake -R498 10" Fixed Black mist Antenna ![]() ©1969-2010 |
ok thanks alot...how much is it gonna cost me (patrts+labor) if its not the key
bump...becuase im bout to go out and want to know if im gonna die or not
afternoon bump
#10 | |
2001 Mustang GT
UNKown
just get a quote.
MM's nicest mod, :)
yeah it has something do with your ignition switch, just like when you don't have a key in the car and try to turn the wheel the steering wheel normally locks up. When you ask questions about prices and how much it will cost to fix every single place is going to be different, when it comes to that just call different places and get a quote cause even if they say 10 dollars your still going to call around everywhere to try to get it fixed. So no need for anymore bumps or evening bumps, just call a shop and tell them what happened and that you would like a new ignition switch and new keys
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
Threads Similar to: Steering Wheel Problem
| steering wheel | terribleonexx88 | 5.0 Mustangs | 2 | March 17th, 2008 08:33 PM |
| Steering Wheel | Baker02125 | Visual | 20 | December 24th, 2007 03:06 AM |
| steering wheel | mustang1072 | V6 Mustangs | 22 | July 26th, 2007 08:35 PM |
| New steering wheel | 69fastback | Classic Mustangs | 5 | July 23rd, 2007 12:14 AM |
| Steering wheel | Nick_Rapitis | V6 Mustangs | 6 | May 25th, 2007 04:39 PM |
